FYI: Intense shift kit is a trans go with added pieces.
What kind of driving do you do mostly?
Don't HV3 then. The HV3 helps in the higher rpm for power. Around the city you wouldn't likely find yourself at that range to see the benefit. The longer runners in the intake currently should be more beneficial for the majority of the driving you do.
