car will start but wojnt stay running for more then 30 seconds and when you try and put it in gear it wont go forward or will shut right off. any ideas on what this could be?
Got gas ?
dont ask how i know, lol
hey my manifold air pressure sensor is broken and i just did a motor swap so im wondering whatever it could be..
no its not flashing, it will stay running for like 20-30 seconds then just shut off.and when i try and put it into drive it wont move forward and just shuts off.
Security related fuel issues are 3-4 seconds. Because the cylinders prime when the key is turned to on, then the injectors do not pulse again.
Determine what you are missing, spark or fuel.
Try unplugged the maf and seeing if you can keep the car running longer.
Pull the IAC and clean it and the bore in the TB.
