Has anyone successfully swapped the UIM on their L36 to a alloy L26 UIM? I have a 01 GT with 175,000 miles and the upper and lower manifolds are leaking. I already had to replace the elbows some time back, now this. I'm done with plastic engine parts. I'm getting the aluminum elbows from ZZP and have a alloy UIM coming. There are several differences between the parts other than the material used. I've seen several posts (none here) suggesting all kind of solutions. I'm looking for someone who has actually made the swap and solved some of the issues. I'm also considering swapping the L67 TB for the oval one that's on there now. That may be more trouble than it's worth though. Has anyone successfully done that? Any help would be appreciated.
Thanks.
