Thread: P0030 and P0036 issues.
Results 1 to 6 of 6
  1. #1 P0030 and P0036 issues.
    minnesota
    I have a 2006 Pontiac grand prix. The check engine came on and i put the code reader on it and P0030 and P0036 keep coming up i tried clearing it. The check engine like came off but the codes still come up. Is this something to worry about? If so how do i go about of fixing this issue?
  2. #2 Re: P0030 and P0036 issues.
    OBD2 - OBDII Code P0036 - HO2S Heater Control Circuit Bank 1 Sensor 2 | Engine-Codes.com read this.
    looks like you need a new o2 sensor, check the fuses first, then the wires, if all that is good id go for a new o2 sensor.
    your mpg will suffer if you dont fix this.
  3. #3 Re: P0030 and P0036 issues.
    minnesota
    Where is the fuse located ? I checked under the hood at about block 14 and it looks like a relay. Or am i looking at the wrong one ?
  4. #4 Re: P0030 and P0036 issues.
    that im not sure about, check inside the cars fuse box as well.
    you can always pull them all one by one and check them. better safe then sorry.
  5. #5 Re: P0030 and P0036 issues.
    minnesota
    I went back under the hood fuses and one of them was blown replaced it and clear them again and now the codes are gone and hopefully stays gone. Thanks though.
  6. #6 Re: P0030 and P0036 issues.
    i love a fix that cost 20 cents lol
  1. Problem with loosing bus communication and a p0030 code
    By LapeerGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-11-2012, 11:08 AM
  2. P0030 & P0135 codes
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2012, 06:03 PM
  3. A few issues
    By Cummins97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2012, 07:55 PM
  4. lcd tv issues
    By kuntzie in forum Off Topic Discussion
    Last Post: 01-06-2012, 11:09 PM
  5. 99 gtp issues
    By Dan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2009, 10:29 PM
