Thread: What is this?
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21
    Ohio
    Exactly what bill said.. My 99 has the smaller hose that you would need up top connected to the n/a brake booster adapter.
  2. #22 Re: What is this?
    Mike..you like how I covered the capped years as well.
  3. #23 Re: What is this?
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    well mines an 01. I thought that it connected to my brake booster line, but idk where the smaller house connected to it goes. Isnt what im holding the brake boost adapter?
  4. #24 Re: What is this?
    Ok.. take a look next to the relay center. Do you see one or two vacuum lines there? One is the washers, the second is the hvac line. It'll run up over the strut tower (ps side) and be clipped to the firewall about a foot off the tower. Likely it's chillin there waiting for you.
    If not.. and if the part your fingers were literally holding had a rubber cap on it..then cap the center of the SC manifold.
  5. #25 Re: What is this?
    Dec 2011
    Decatur
    Ok yea thats the hose im holding that runs up the strut tower but i still dont see where it plugs into. And no it didnt have a cap i think it was connected to my brake booster.
  6. #26 Re: What is this?
    Dec 2011
    Decatur
    does anyone have picture of where it should be on both n/a and supercharged
    Aug 2011
    Kenosha
    I have a top swapped gt and ill take a video of how my HVAC line is ran. Give me a little bit.
    Aug 2011
    Kenosha
    Or do you just need to know where to plug the HVAC line into? I plugged mine into a port on that tree on top of the supercharger to the right of the fuel lines.
  9. #29 Re: What is this?
    See the vaccum ports on the top of the SC by the TB end. Big hose is brake booster, middle is hvac, front most one is the BCA .
  10. #30 Re: What is this?
    Dec 2011
    Decatur
    thanks thats what i need
  11. #31 Re: What is this?
    Dec 2011
    Decatur
    Hey josh i sent you a pm.
  12. #32 Re: What is this?
    Dec 2011
    Decatur
    http://i1321.photobucket.com/albums/...ps3732bf34.jpg. I still can't find where this middle sensor goes. Can anyone tell me
  13. #33 Re: What is this?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    no where
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  14. #34 Re: What is this?
    map or evap sensor plug?
  15. #35 Re: What is this?
    Dec 2011
    Decatur
    No I swapped my map for l67. Where's the evap go?
  16. #36 Re: What is this?
  17. #37 Re: What is this?
    Dec 2011
    Decatur
    I think he was right I don't need it I guess.
