Thread: wont start after top swap
Results 1 to 20 of 23
  1. #1 wont start after top swap
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Just finish top swap and my car won't start it cranks but then locks. Can anyone help?
  2. #2 Re: wont start after top swap
    You should really just add on to your other threads, instead of making tons of new ones.
    But anyway, do you have spark and fuel? All connectors plugged in?
    What do you mean locks?
  3. #3 Re: wont start after top swap
    Dec 2011
    Decatur
    Like its popping then just quits and I checked spark it sounds like it wants to fire but then drops. And all the dash lights blink
  4. #4 Re: wont start after top swap
    Sounds like you dont have fuel.
  5. #5 Re: wont start after top swap
    Dec 2011
    Decatur
    So what should I do
  6. #6 Re: wont start after top swap
    Check for fuel at the rail? Does the fuel pump even run?
    Double check all spark wire routing, you might have it wrong.
    I mean you did just do a top swap, so you should have some of this down.
  7. #7 Re: wont start after top swap
    Dec 2011
    Decatur
    Haha it was spark guys thanks though
  8. #8 Re: wont start after top swap
    derp
  9. #9 Re: wont start after top swap
    Dec 2011
    Decatur
    Tell me about it, that's what happens when you let your friend hook them up
  10. #10 Re: wont start after top swap
    Dec 2011
    Decatur
    My supercharger sounds like rocks are tumbling around at idle. I put a new coupler on it so idk what to do.
  11. #11 Re: wont start after top swap
    Just deal with it?
    Buy another on from ZZP or ebay?
  12. #12 Re: wont start after top swap
    Dec 2011
    Decatur
    What about bearings or anything?
  13. #13 Re: wont start after top swap
    Dec 2011
    Decatur
    So there's no way to fix it? Will it hurt anything to drive it until u get one? That's my main concern.
  14. #14 Re: wont start after top swap
    if the coupler is good, them its probably the bearings gone bad.
    it maybe cheaper to just get a used blower and slap it on.
  15. #15 Re: wont start after top swap
    Dec 2011
    Decatur
    Yea I put a new coupler on. I'll buy a used one. But it ok to drive for a little if I take it easy I mean I still have the 500 mile break in.
  16. #16 Re: wont start after top swap
    500 mile break in? theres no break in for a top swap.
    back in the day you had to break in the cam and lifters, being we use roller lifters you dont need to break them in at all.
    that goes if you have a whole new engine, bottom end to top, its go or blow, some say driving it like you stole it right out of the box sets the rings better as well.
    no amount of babying the car will save it is something is not right.
    in your case you may just want to pull the belt off the sc, if the rotors are touching it could send metal chips into he engine.
  17. #17 Re: wont start after top swap
    Dec 2011
    Decatur
    Ok ill have to pull it off
  18. #18 Re: wont start after top swap
    Dec 2011
    Decatur
    Is there a way to check for bad bearing?
  19. #19 Re: wont start after top swap
    if the coulper is tight feeling still, then you would need to take it off and take it apart to inspect it.
    if the sound is gone with the sc belt off you know its related.
  20. #20 Re: wont start after top swap
    Dec 2011
    Decatur
    Ok thanks man
  1. 04 gtp wont start
    By BlackCompg04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2012, 08:53 AM
  2. car wont start
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2012, 09:45 AM
  3. new used pcm car wont start
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2011, 09:43 AM
  4. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  5. Car wont start
    By jluca in forum General Tech Discussion
    Last Post: 12-01-2010, 08:37 PM
