Thread: Exhaust leak on both sides
Results 1 to 6 of 6
  1. #1 Exhaust leak on both sides
    Fargo, ND
    Just noticed an exhaust leak on my 02 GT this morning. It's dripping quite consistently, and leaving a puddle. The location of the leak is at the part where the pipe connects to the actual muffler, so about 3-4 inches behind the rear wheels. This is happening on both sides of the exhaust. Is this something that will require a whole new exhaust? Or can I just get new mufflers?
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    It's the drain holes in the front of the muffler to drain water and condensation. Unless you have a hole in the pipe it's normal, well every one I have seen does this to some extent.
    Sent using Tapatalk 2 from my GS3.
  3. #3 Re: Exhaust leak on both sides
    welcome to winter time. most newer cars have this hole in the muffler to let moisture leak out. helps keep the mufflers from rotting out.
  4. #4 Re: Exhaust leak on both sides
    Fargo, ND
    I guess I've never noticed it before until now.... I've had this car for 7 years. Guess I'm the idiot of the day then.
  5. #5 Re: Exhaust leak on both sides
    Indianapolis
    finally i can pass the crown off to someone else for once
  6. #6 Re: Exhaust leak on both sides
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Quote Originally Posted by PigSnoutKid View Post
    Just for today, though...
  1. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  2. gtp exhaust leak??
    By tichota126 in forum General Tech Discussion
    Last Post: 05-27-2012, 10:39 PM
  3. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  5. Need help with an exhaust leak
    By thenervemann in forum General Tech Discussion
    Last Post: 04-26-2009, 09:28 PM
