Thread: need help w 08 gp. oil smell under hard acceleration.
Results 1 to 6 of 6
  1. #1 need help w 08 gp. oil smell under hard acceleration.
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    I looked on past posts but didnt find anything. When I step into it, i smell oil inside the car. I had an oil pan leak but i changed it months ago. And also when i do step into it, it revs out and red lines, it doesnt switch in the next gear like it should. It has 110k kms/60k miles. i brang it to the dealer and they said its fine. i know different. thank you
  2. #2 Re: need help w 08 gp. oil smell under hard acceleration.
    Yoga city
    well sounds like theres a trans slippin a bit and oil could be blowing out the volve cover and burning onthe exhaust. your gonna have to clean up the area's and recheck for leaks
  3. #3 Re: need help w 08 gp. oil smell under hard acceleration.
    Pennsylvania
    Under acceleration, the engine tips back toward the firewall and more oil moves to the rear head, sloshing out your leaking valve cover gasket on to your exhaust manifold, causing smoke.
    Grab a mirror and look behind the engine. See oil dripping out the valve cover?
  4. #4 Re: need help w 08 gp. oil smell under hard acceleration.
    Nov 2011
    north bay, ontario
    thankls, il give that a try. i dont think i ever felt the tranny slipping. the reving issue i was thinking might be a sensor issue, or the torquer converter. no codes were ever set for it.
  5. #5 Re: need help w 08 gp. oil smell under hard acceleration.
    Pennsylvania
    Which gear is it redlining in? all of them?
    I'll go ahead and say clean your MAF sensor wires with MAF sensor cleaner spray, and the throttlebody with throttlebody cleaner and a toothbrush and rag.
  6. #6 Re: need help w 08 gp. oil smell under hard acceleration.
    Nov 2011
    north bay, ontario
    it redlines in any gear. when i stomp on it at any speed it just revs out and doesnt switch gears. and as i said oil smell when i do the same. I know theres alot of good guys here whio know there stuff. I just wanna fix it before it bcomes a bigger problem that i wont be able to afford. I did clean the maf sensor, i took the whole intake off and cleaned it well. it was bad. thank u
  1. Car hesitates under hard acceleration
    By GTLGDP in forum General Tech Discussion
    Last Post: 03-10-2012, 12:16 AM
  2. 99' GTP Struggles under hard acceleration?
    By jwjones in forum General Tech Discussion
    Last Post: 02-12-2012, 02:52 PM
  3. sputter on hard acceleration
    By mskram1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2011, 02:00 PM
  4. Shuttering on hard acceleration
    By Pshnmeawy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2011, 01:52 PM
  5. Lock up TC engages hard on acceleration
    By dearmond in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-30-2009, 12:01 AM
