Thread: Vacuum Line Part Number?
Results 1 to 5 of 5
  1. #1 Vacuum Line Part Number?
    Springfield Missouri
    So Ive been fighting with a vacuum leak for a while now and I finally found it! Only problem is I dont know what you would call this line. It is the Vacuum line that goes into the throttle body then comes out to the evap system. it is a 2 line system the other hose goes to the Fuel pressure regualator spot. I went to Autozone and the guy told me that they diddnt carry such a thing and told me good luck any help please?
  2. #2 Re: Vacuum Line Part Number?
    just broke mine line there too. i used a fat vac hose to fit on the fat tb nipple, then stuck a smaller line inside the fat one, then back the plastic factory line.
  3. #3 Re: Vacuum Line Part Number?
    you can see the fat line bending back towards the rear, its bending through the wire harness.
  4. #4 Re: Vacuum Line Part Number?
    heres a better pic i just took.
  5. #5 Re: Vacuum Line Part Number?
    Mar 2012
    Minnesota
    I just broke this line doing it on an impala during an intake manifold fix, autozone had a reel of vacuum line and the salesman just cut me off a five inch section or so, got it free too! Score.
  1. transmission cooler line part number?
    By andremike in forum General Tech Discussion
    Last Post: 11-17-2014, 08:31 PM
  2. I bought the factory Vacuum line $52 with tax pic with part number
    By ryan12473 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2012, 04:43 PM
  3. EVAP canister purge valve vacuum line part number
    By Freimuth in forum General Tech Discussion
    Last Post: 04-18-2012, 11:00 AM
  4. L67 Vacuum Line Kit Part Numbers and Prices
    By MoarkatsINmuhtrailer in forum How To Write-Ups/Tech Tips
    Last Post: 01-16-2012, 01:19 PM
  5. Vacuum line parts number?
    By GAFF in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 01:51 AM
