http://www.youtube.com/watch?v=1fVTzRAFdTE
this is why people turbo
Well with income taxes and what I can save between now and then around 4k
buy a supercharged 3800 from a junk yard with low miles. and buy a turbo kit. you wont need to touch the bottom end of a supercharged engine. they are bullet proff
Yea thats fast lol. My squad Sgt had a turbo'd mazda speed 6, it was fast. but he wound up blowing the engine. And im afraid of that. auto trans + turbo = boom lol
The L26 is a iron block, same as all 3800 motors.
The rods are the weakest out of all the motors. It can handle some power but are more prone to breaking in higher HP builds.
I'm going to be blunt, the NA 3800 is not going to be a power house, you would have to add boost to make it something worth while.
If I was you, make this car cool sounding and lower it and make it handle good. Do a NA cam with supporting mods.
There is tons of info on this site for mods and what you'll need to make it happen.
And once your over say 300-350HP the trans is going to become very weak.
Thank you for confirming that I was wrong. I don't want to bust anything up, do you think I can make a turbo work?
Yes a turbo can always work, you're just at the will of the motor.
Having the correct mods and a good tune is always wanted to make sure it can survive.
If it ever blew up, swap in a L36 or L67 bottom end.
he could do that now
Sweet thanks for confirming. Ill search around the forums before I make any other threads(after I do my rounds, im at work lol), How much do you think I would have to invest to get maybe 260-280HP?
Going to do rounds ill Be back in 45 minutes. thanks you all for the advice Im now pointed in the right direction.
I would read this first if I were you.
http://www.grandprixforums.net/safel...0-a-67580.html
A topswap would be the cheapest way get close to where you want to be.
If you don't go crazy with a topswap, you should be pretty happy with the power you will be putting down.
You guys are awesome, ill def be donating for the bandwidth on Friday. I found a new car owners home!
Reading now, its a wealth of knowledge that saved me my engine. Thank you!
It's a 5.3L in the gxp guys not 5.8L
I didnt see much on dropping a supercharger or turbo on a stock..
http://www.grandprixforums.net/top-s...info-7763.html
:th_beer-toast2:
