Thread: Coolant Leak
Results 1 to 6 of 6
  1. #1 Coolant Leak
    Oct 2012
    A few months ago I bought an 04 GP, 130k miles. Today I noticed that its dripping coolant, I did some research and couldn't find my problem. I circled the area where it seems to be the most wet, but I still can't find the leak.
    I checked a few things already, both plastic elbows seem to be fine, the oil isn't "Milky".IMG_0414.JPG
    thanks for any help.
    Ohio
    It's probably the elbows. Even if they aren't cracked, they might not be sealing and it's dripping out.
  3. #3 Re: Coolant Leak
    Oct 2012
    So if the oil isn't milky is there anywhere else it could be leaking? I checked the elbows and they seemed to have some seepage, nothing that looks like it was dripping.
  4. #4 Re: Coolant Leak
    seepage turns into dripping when pressure is applied
  5. #5 Re: Coolant Leak
    Apr 2011
    Elk Rapids, Michigan
    If you do replace the elbows, get the new Dorman aluminum version. They're much stronger than the plastic ones. I got mine at O'Reilly's for around $12. Rock Auto also has them. I replaced them when I did LIM gaskets and a new upper intake manifold. It fixed my coolant leak.
  6. #6 Re: Coolant Leak
    Oct 2012
    Brampton,ON
    Its most likely the coolant elbows. I had the same problem on my 04 grand prix gt, i just had it fixed
  1. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  2. coolant leak
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2011, 11:56 PM
  3. bad coolant leak
    By johnfolks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2011, 04:30 PM
  4. Coolant Leak
    By rippemblue2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2010, 11:30 AM
  5. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
