Thread: 1.9 modded rocker arms
Results 1 to 20 of 22
  1. #1 1.9 modded rocker arms
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Im wanting to get a set of rocker arms and im just wondering what springs and retainers i would need so that i dont have to worry about valve float? Im doing this on my top swapped grand prix by the way.
  2. #2 Re: 1.9 modded rocker arms
    The minimal gains from rockers make it pretty much not worth it if you ask me.
    Ohio
    Cam or nothing
    Quote Originally Posted by 99pgpgt View Post
    Cam or nothing
    This
    04 Comp G.
  5. #5 Re: 1.9 modded rocker arms
    Dec 2011
    Decatur
    I know a cam is way better but that wasn't my question.
  6. #6 Re: 1.9 modded rocker arms
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Gotta love the support you get from GPF... I did 1.9 RR's and actually felt a good gain. I did 90# LS6 springs along with locators, beehive spring retainers (Manley), and comp locks. I believe they were installed at 1.720". 115# on the seat 300# open at .488 lift.
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  7. #7 Re: 1.9 modded rocker arms
    Dec 2011
    Decatur
    I know lol if i wanted to know which was better i would of asked but thanks thats what i was looking for i was debating on whether or not to get the 90#s or the 105#s.
  8. #8 Re: 1.9 modded rocker arms
    May 2011
    United States
    Either will work fine. I chose the 90# cause they were cheaper
  9. #9 Re: 1.9 modded rocker arms
    Quote Originally Posted by Sushamouf View Post
    Yeah, whole forum sucks because the first two guys didn't answer the question. Please cut negativity and add the good info you know, instead of adding to the issue.
    OP
    Personally I wouldn't suggest the LS6 springs as they are tougher on the timing chain and dampner based on their spring rates as they are compressed. 105's or LS9/L76 would be a better choice. Proper install height on any LS based (LS6, L76/LS9, or 105) is expected/suggested to be 1.800". Our heads with stock retainers will yield 1.72x", with modded/Manley retainers you will see 1.78x" which is how 99.9% of people run.
    As for rockers. If you don't already have the 1.9's. I'd suggest looking for ER's. They tend to get more performance out of an NA motor than 1.9's.
    1.72 is asking for trouble with those springs.
    .490 max lift is your limit at that height. That's right around what you'll see with 1.9s.
    Is bad advice better than no advice?
    Calculate spring pressure at your lifts.
    Apparently 105s will be lower than ls6s with rockers.
    You could also throw some l76 springs in there. Moderate spring rate 90s.
    But its not like this hasn't been covered a thousand times.
  11. #11 Re: 1.9 modded rocker arms
    May 2011
    United States
    Actually max lift is .500. They were set up by an engine builder that does heads all day everyday. The guides were machined along with liners and retainer-to-seal clearance was checked along with coil bind. They are perfectly fine, you just need to know what you are doing.
    Rated max lift is 570 when installed at 1.8.
    What sort of magic math do you speak of?
    If a pro set them up he would have asked for the recommended install height. Right now your seat pressure is probably way too high meaning you're going to see even more wear than you would normally expect out of ls6's.
    You'll see 120 seat, 304 open.
    Compared to 98 seat, 282 open.
    May 2011
    United States
    No, its .580 at 1.800 and therefore .500 at 1.720 and I looked, my install height with the locators was 1.770 not 1.720.
    Sent from my Droid
  14. #14 Re: 1.9 modded rocker arms
    Dec 2011
    Decatur
    OP
    i have a top swap so wouldnt 1.9s be good?
  15. #15 Re: 1.9 modded rocker arms
    I didn't realize that and you posted in the NA section. Sometimes I make uncaffinated posts.
    1.9's are fine with a top swap.
  17. #17 Re: 1.9 modded rocker arms
    Dec 2011
    Decatur
    do the springs come with retainers and locks or do i have to buy them separatley
  18. #18 Re: 1.9 modded rocker arms
    Ohio
    separately
    May 2011
    United States
    I recommend the Manley retainers, ther offer more clearance to the rocker tip.
    Sent from my Droid
  20. #20 Re: 1.9 modded rocker arms
    Topeka, KS
    Go cam. I went rockers and wish i went cam instead every day!
  1. rocker arms?
    By 02 monte carlo ss in forum General Tech Discussion
    Last Post: 02-13-2011, 05:02 PM
  2. rocker arms
    Last Post: 02-12-2011, 09:41 PM
  3. rocker arms cam help
    By wking2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-13-2010, 04:39 PM
  4. Rocker Arms
    By stlmo_gtp in forum PCM Tuning
    Last Post: 10-01-2009, 11:08 PM
  5. 1.9 Rocker arms
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 03:07 PM
