Thread: Front Motor Mount DIY-able?
Results 1 to 20 of 22
  1. #1 Front Motor Mount DIY-able?
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Hey so i picked up my front motor mount and was wondering if this was a DIY able thing.
    Any tips or tricks from the old pros?
    Preferably dont want to have an engine one my face so any help is okay
  2. #2 Re: Front Motor Mount DIY-able?
    Yoga city
    what is you talking about?
    Mar 2012
    Minneapolis MN
    Quote Originally Posted by Jteske88 View Post
    The lower engine mount?
  4. #4 Re: Front Motor Mount DIY-able?
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    u trying to ask how to install it? if so remove nuts then remove upper dog mount . get a jack and some stands and a peice of wood jack car up install jack stands put wood on jack and jack up on oil and trans pan and slide the mount out and install new mount can be done in any driveway dont even have to remove the tire if u wanna work around it LOL
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
    Mar 2012
    Minneapolis MN
    Quote Originally Posted by 00grandprixgtp View Post
    Yes lol thats what i was asking...
    I'm a little out of it today
  6. #6 Re: Front Motor Mount DIY-able?
    It helps alot with 2 people, trying to line the bolt holes up by yourself can get annoying while lowering the jack.
    Mar 2012
    Minneapolis MN
    I see i see.
    I may has help on this.
  8. #8 Re: Front Motor Mount DIY-able?
    I drop motors in and sometimes they fall right into place. Other times..a little work is needed. All depends on your luck at that moment.
    If you checked the how to section....I'm sure you'd find something with my name on it.
  9. #9 Re: Front Motor Mount DIY-able?
    i changed both my lower mounts solo. its so doable.
    all you need is a jack and a 2x6 thats 2 feel long to span the oil pan and trans pan to lift the engine up a few inches, also unbolt the top strut mounts.
    heres a vid how to do the trans mount, the motor mount is the same deal. the top bolts are just a bit harder to get off being under the oil pan a bit.
    there are 3 parts to this vid.
    Ohio
    More like being under the harmonic balancer.. Makes them a pain to get to. You'll want a ratcheting wrench because a socket won't get in there
  11. #11 Re: Front Motor Mount DIY-able?
    more like past the balancer and under the pan still.
    Ohio
    Well we can agree that the nuts are a *****
  13. #13 Re: Front Motor Mount DIY-able?
    by all means, yes, we can agree on that.........
  14. #14 Re: Front Motor Mount DIY-able?
    I think you both are a couple of wusses. I find that a shallow 15mm socket and the thin head ratchet do the job with ease.
    What can I say..I have a few tools.
    Mar 2012
    Minneapolis MN
    Top bolts are a b!tch. Refuse to come off lol
    Mar 2012
    Minneapolis MN
    But i got it....
    Think i needed a new motor mount?
  17. #17 Re: Front Motor Mount DIY-able?
    Top bolts were tough...because of one of the following
    1, You are a wuss.
    2. You don't have the right tools.
    3. You did it wrong.
    Mar 2012
    Minneapolis MN
    1, You are a wuss.
    I'd aim at using a basic socket wrench.
    Having 3 shots in my dominant arm last night.
    And 200,000 miles. Its the original mount lol
  19. #19 Re: Front Motor Mount DIY-able?
    idk, your looks pretty good compared to mine.
    Mar 2012
    Minneapolis MN
    Holy shieett! You're right lol you really let that sucker go.
  1. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  2. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  3. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
  4. Front Motor Mount Brackets..
    By GP2003GT in forum Visual/Body Modifications
    Last Post: 03-31-2008, 11:31 AM
