Thread: got some codes need help
Results 1 to 7 of 7
  1. #1 got some codes need help
    Sep 2012
    fort Wayne, in
    Ok so I have a99 gt, and having some issues with acceleration, so I got it scanned and got p0141 and p0134 so I'm needing some direction please help
  2. #2 Re: got some codes need help
    Sounds like your front o2 is bad.
  3. #3 Re: got some codes need help
    Sep 2012
    fort Wayne, in
    So is that up stream or downstream? And both the codes are o2 sensors so the second o2 is for my cat right?
  4. #4 Re: got some codes need help
    Upstream. The p0420 code is for the cat.
  5. #5 Re: got some codes need help
    Sep 2012
    fort Wayne, in
    So my cat could be clogged or could the sensor be bad?
  6. #6 Re: got some codes need help
    Sensor is probably bad.
  7. #7 Re: got some codes need help
    If you listed the names for the codes, we could probably easily tell you if it's an O2 or not.
    When you list codes, please ... list the name.
  1. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  2. Ecu codes
    By dmack976 in forum Engine
    Last Post: 02-11-2012, 10:39 PM
  3. Codes
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2011, 07:02 AM
  4. Codes for A/C
    By ASTROALCHER in forum Introductions/Noob Questions
    Last Post: 09-08-2009, 12:49 PM
  5. GM RPO Codes
    By mkuhn20 in forum General Tech Discussion
    Last Post: 01-21-2009, 04:47 PM
