Thread: Intake manifold gasket
Results 1 to 12 of 12
  1. #1 Intake manifold gasket
    Lubbock,TX
    I have a 1997 gp gt. I need to change the intake manifold gasket and wondering if I need the kit that comes with the pins or the kit without pins... The parts store carries both but they don't know if my vehicle requires the pins or not....Thanx Rudy
  2. #2 Re: Intake manifold gasket
    Oklahoma
    Moved to the correct section.
  3. #3 Re: Intake manifold gasket
    Barksdale AFB, LA
    What pins?
    2009 Subaru Impreza WRX STI
  4. #4 Re: Intake manifold gasket
    Lubbock,TX
    the locating pins????
  5. #5 Re: Intake manifold gasket
    NE Ohio
    afaik theres no such thing...
    and what kit?
  6. #6 Re: Intake manifold gasket
    Barksdale AFB, LA
    Quote Originally Posted by rudyram118 View Post
    There are pegs that the gaskets line up on. Here are the gaskets installed sitting on the pegs:
  7. #7 Re: Intake manifold gasket
    GTP Level Member Scimmia's Avatar
    QCA, IA
    IIRC, sometime in 97 GM added holes for locating pins on the end seals for the LIM. I believe on the earlier design, there was simply nothing there, so the one with the locating pins should work fine either way.
    This is all assuming you're staying with plastic gaskets. AFAIK, there's only one kit (with pins) for the aluminum framed gaskets, which are what I would use.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: Intake manifold gasket
    NE Ohio
    i didnt use any alignment pins or anything like that reinstalling my lower intake and new aluminum gasket..
  9. #9 Re: Intake manifold gasket
    QCA, IA
    Quote Originally Posted by kyle99gtp View Post
    The pins we're talking about are molded into the gaskets that go on the ends of the lifter valley. Everything after 97 should have them, AFAIK.
  10. #10 Re: Intake manifold gasket
    I have a 97 gpthat i am about to do the lim and uim also. I hit the same snag with the pinned and unpinned version of the aluminum uim lim gaskets. I believe someone said there is only one version but i found
    pinned gm # 89017816
    unpinned # 89017817
    aluminum versions
    I have also heard peeps stating that the felpro replacement are better than the aluminum and im curious what others have used?
    i ordered one pinned and one unpinned version of the gaskkets because no parts person has been able to give me a way to tell what i have before before i open it up. I'm doing this repair off of sabrewings article on the repair which is very clear so thanks for that.
    Sabrewings out there? You had such good info on this repair i have a couple questions but dont see a way to p.m. ya.
    Thanksall
  11. #11 Re: Intake manifold gasket
    Barksdale AFB, LA
    If you click on a person's name it gives the option to PM.
    Anyway, I'm not so sure about this pinned/unpinned stuff. Nor have I seen the FelPro version of the gaskets. I know the aluminum gaskets from GM are great since that's what I used along with an updated design of the UIM gasket. Both the LIM gaskets and UIM gasket were new from GM in the bag. All I had to do was hold the GM aluminum gaskets and I knew they'd work just fine. Thick and sturdy.
    Disclaimer, based off what others have said your 97 will be slightly different in the alternator bracket area than mine. I haven't personally opened up a 97 3800, but plenty here have and if I can't answer your question or it isn't obvious, this is a good place to get help.
    Aside from that, I'm open to questions in PM if you still need some answers. I am currently out of town and won't be back for a few days. Managed to get some dial up here... >.<
  12. #12 Re: Intake manifold gasket
    Lubbock,TX
    could the plenum gasket cause this as well?
  1. Replies: 84
    Last Post: 09-09-2015, 08:10 PM
  2. Upper Intake Manifold Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 01-06-2012, 10:34 AM
  3. turbo manifold >?
    By sal3800 in forum Turbo
    Last Post: 04-09-2008, 06:33 PM
  4. Exhaust Manifold bolts
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 06:05 PM
