That is expensive. My catback was free.
i wouldnt return a scanner
Buy new MAF...try it out for a week see if problem persist if it does then return the Maf if not you found your problem..not sure how much simpler i can make it
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
I don't think you can return electronics after they have been used.
Autozone lets you.
They changed that policy when I worked there a few years back.
hmmm good to know lol
But most of their products are junk anyways electrical...yay awesome fuel pumps too.
If you know who works at a certain store you can get away with returning an electrical part.
Who werks at Advanced Tardo?
I thought i had issued with my MAF but it ran the same way unplugged so its not my MAF. I was about to replace the throttle position sensor when i thought about cleaning the throttle body first. Its seriously only took 15 miniutes to pull it off and put it back on but it took me an hour to clean it shiny like winterstorm pictures. i put it back on and it still had a LOT of hesitation and no acceleration (even floored!!) under load, up hills, etc. So i decided to put in the new TPS, but that hasnt worked either. It was worse than ever so I put back the old one and its improved a little. What did i do wrong? It looked tlike the gasket sealed right (with 4 bolts) when i put the TB back on, but was i supposed to use wax or some other king of sealer on the TB/manifold gasket???? How the he!! d oyou find a vacuum leak???
