Thread: MAF Problem?
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 112
  1. #41 Re: MAF Problem?
    The only thing that happened here was you getting lucky.
    And you still don't know if it has a vacuum leak because you don't have a way to scan it.
    So therefore, I'm technically not wrong until you can prove it with a scan.
  2. #42 Re: MAF Problem?
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    i sprayed some stuff my dad had to check for leaks that bubbles up when there are there were no leaks
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  3. #43 Re: MAF Problem?
    Ok.
  4. #44 Re: MAF Problem?
    Jun 2012
    Connecticut
    lol im sry but im just going to savor the one time i was right/ever going to be right about something we were going back and forth about
    2005 Grand Prix GT
  5. #45 Re: MAF Problem?
    Ok..
  6. #46 Re: MAF Problem?
    Quote Originally Posted by winterstorm View Post
    A vacuum leak would suck fluid in not bubble it up.
  7. #47 Re: MAF Problem?
    I'm sure it did that too.
  8. #48 Re: MAF Problem?
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    Hey Winter, you never said how the car ran after cleaning the TB. Is the issue gone? Just curious as I'm having the same issue on my 02' NA and I'll be doing the MAF and TB tomorrow morning.
    2002 GT Red, Stock, Work In Progress..........
  9. #49 Re: MAF Problem?
    Jun 2012
    Connecticut
    Quote Originally Posted by blueguy91 View Post
    well nothing happened at all i would have noticed stuff getting sucked in. now i feel dumb that i said it would have bubbled up because i know better lol. but yeah nothing happened. and again i emphasize that i watched the gasket seal. there was not even the slightest crack between the tb and the intake manifold. and no codes were thrown because the check engine light didnt come on.
    2005 Grand Prix GT
  10. #50 Re: MAF Problem?
    Jun 2012
    Connecticut
    Quote Originally Posted by 02GPinNY View Post
    i cant be sure for about a month because the problem is very intermittent. sometimes it happens often sometimes not for weeks. so ill keep ya updated. i can say for sure that the car starts up real quick now after i cleaned the throttle body. starts as quick as the snap of your fingers so i can notice the cleaning helped in some way haha.
    2005 Grand Prix GT
  11. #51 Re: MAF Problem?
    Aug 2012
    Port Chester, NY
    Thanks for the update. I'm actually heading down in about 15 minutes to start doing mine. I'm keeping my fingers crossed that this clears up the issue. Mine doesn't throw up any codes either and is also intermittent.
  12. #52 Re: MAF Problem?
    gardner,mass
    your going to need a new gasket on an 02 its not like the 04+,its a metal type that falls apart when you take it apart
    Take the maf out and clean it only with maf cleaner dont go spraying carb cleaner in the tb with the maf in there
    Also your maf is a dime a dozen in the jy and can probly get one for 20 bucks so do the maf d/c test to verify the maf is having issues if it is just grab one from the jy for next to nothing, map sensor too could cause issues
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  13. #53 Re: MAF Problem?
    Jun 2012
    Connecticut
    yup ginseng is spot on dude.
    2005 Grand Prix GT
  14. #54 Re: MAF Problem?
    A vacuum leak doesn't always toss a P0171.
    You also can't prove it isn't leaking without a scanner.
  15. #55 Re: MAF Problem?
    Jun 2012
    Connecticut
    lol wutevs dude. all i can say is that with the 3 bolts the tb was on there just as good as it was with 4, and when i put the 4th one on it didnt make any difference as to how tight the tb was on there, no difference at all. the tb was already on there real good and the gasket was sealed.
    2005 Grand Prix GT
  16. #56 Re: MAF Problem?
    ok, you're the expert.
  17. #57 Re: MAF Problem?
    Jun 2012
    Connecticut
    i know im not the expert lol. man i shoulda taken pictures so you guys would believe me lol
    2005 Grand Prix GT
  18. #58 Re: MAF Problem?
    Vacuum can get through very tiny holes. It way have looked sealed up but likely was leaking a little
  19. #59 Re: MAF Problem?
    Jun 2012
    Connecticut
    idk man lol it was in there pretty good. but im not trying to argue with anyone so this is all im saying lol
    2005 Grand Prix GT
  20. #60 Re: MAF Problem?
    Aug 2012
    Port Chester, NY
    Quote Originally Posted by ginseng View Post
    Yes, I had gotten a new gasket and two different cleaners, one for the TB and the other for the MAF. I'm back upstairs now and the car starts and runs fine now, cold and hot. It was really dirty to say the least. I have seen worse but it surely had a bunch of crud built up around the blade in the TB. I had only two small issues doing the job which I'll post up with some pics.
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. HUD Problem. Please help.
    By VejGTP in forum 04+ Specifics
    Last Post: 07-21-2012, 01:57 PM
  4. hud problem help please
    By lorello in forum Audio, Security & Visual Electronics
    Last Post: 10-24-2011, 06:38 AM
  5. First Problem Need Help
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 03:30 PM
