Thread: Meth Injection Kit
Results 1 to 17 of 17
  1. #1 Meth Injection Kit
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    How hard is it to install a meth injection kit. What kind of tuning will i need. Im about to do a top swap. I want to run a 3.2 pulley with headers, colder plugs, 180 therm, CAI,and stage 2 intercooler. If i didnt get the intercooler could i run a 3.2 still with those mods and meth injection?
  2. #2 Re: Meth Injection Kit
    Omaha, NE
    Here are directions from the devils own kit.
    Progressive Stage 2 DVC-30 Directions - DevilsOwn Injection
    That's for this model which includes a controller, I'm unsure of what other tuning may be necessary.
    DVC-30 methanol Injection Kits : DevilsOwn water Injection
  3. #3 Re: Meth Injection Kit
    Dec 2011
    Decatur
    Thanks do you know where i should place the nozzle? And what do you think bout pulley sizes?
  4. #4 Re: Meth Injection Kit
    Omaha, NE
    There's a great write up somewhere on here by bio about putting the nozzle in the blower housing. I know people also like to tap into throttle body spacers if you don't feel comfortable tapping your sc housing.
    As far as pulley, I would get HPTuners and a wideband and tune yourself. Then you can also monitor for KR, which will be the main factor in dropping pullies.
  5. #5 Re: Meth Injection Kit
  6. #6 Re: Meth Injection Kit
    Dec 2011
    Decatur
    Thanks Bio and i seen that you made a post on where to put it. I was wondering where did you end up putting it and what kind of gains did you see.
  7. #7 Re: Meth Injection Kit
    Dec 2011
    Decatur
    Never mind i see the post where you put it lol
  8. #8 Re: Meth Injection Kit
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    **** works great. If you are running a gen V blower, drill and tap the little bump on the top of the blower directly behind the tbody flange
  9. #9 Re: Meth Injection Kit
    You won't get away with a 3.2" with meth and an IC with a stock valvetrain on high compression without running fat on the AFR side and high EGT's with crap timing.
    Think 3.4"~
  10. #10 Re: Meth Injection Kit
    Dec 2011
    Decatur
    Ok what if i added rockers? the modded 1.9s? And how much whp do you think ill be making?
  11. #11 Re: Meth Injection Kit
    Rockers aren't gonna open up enough flow for a .2" pulley drop.
    Maybe if you piggy'd up the AFR and ran a 3.2"...you'd get low end TQ but it'd taper off pretty quick. Rockers might add 10-15 WHP...maybe. If you did 1.95 rollers.
  12. #12 Re: Meth Injection Kit
    Dec 2011
    Decatur
    So pretty much the only way to run a 3.2 pulley the right way is by getting a cam?
  13. #13 Re: Meth Injection Kit
    i ran a 3.2 on meth with rockers.
    i can agree that over-modding is usually the best route to take, but i think our mentality around here has gotten a little extreme.
  14. #14 Re: Meth Injection Kit
    Dec 2011
    Decatur
    Was this on a top swapped set up?
  15. #15 Re: Meth Injection Kit
    nope, L67 block because i spun like 3 bearings at the same time on my L36 block and replaced it.
  16. #16 Re: Meth Injection Kit
    So like I said, 3.2" on low comp. and 3.4" on high comp.
    If you ran the IC and the methanol you might get away with a 3.2"...maybe.
  17. #17 Re: Meth Injection Kit
    Dec 2011
    Decatur
    Ok thanks for the info guys!
  1. DIY Meth injection ?'s
    By TEK310 in forum General Tech Discussion
    Last Post: 06-23-2012, 01:23 PM
  2. Well I done did it guys.(Meth Injection)
    By ChrisJ in forum General Tech Discussion
    Last Post: 04-19-2009, 10:58 AM
