Thread: car won't start
Results 1 to 13 of 13
  1. #1 car won't start
    Aug 2012
    Oregon
    2000 grand prix, 3.8 NA
    car died while my mother was driving it. low on gas (we thought) since the gauge read empty. put gas in car, would not roll over, just clicked. battery had a bad cell, replaced battery. still nothing. replaced starter unit. still won[t roll over, and 20 gal of gas in car and still reads empty. very little money, need car very soon for school.
    help!!!
    okay, how do i check the security system, the card or the reader??? can i just get a new one from the dealer if i give him my vin number???
  2. #2 Re: car won't start
    Even if it was a security issue it should still turn over. It could have hydrolocked. Pull the spark plugs and turn it over and see if coolant comes out.
  3. #3 Re: car won't start
    Jan 2012
    Florida
    Is it at least cranking, but just wont start since you replace the battery and starter? Take a look and your oil dipstick and make sure it doesn't look like coffee. If is does you have a blow head gaskit. If its turning over and wont start you could also try disconnecting the mass air flow sensor.
  4. #4 Re: car won't start
    He doesnt have a bad head gasket
  5. #5 Re: car won't start
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    batt post good? wires good? crank fuses good?..
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  6. #6 Re: car won't start
    Try turning the motor by hand wtih a socket on the harmonic balancer bolt and or take out all the plugs. If you get water, look up the L36 LIM failure thread and that'll help you get it fixed up.
  7. #7 Re: car won't start
    Aug 2012
    Oregon
    It will turn over if you jump across the solenoid terminals, but still will not start.not an oil or water problem.
  8. #8 Re: car won't start
    Aug 2012
    Oregon
  9. #9 Re: car won't start
    This is making me think ignition switch.
  10. #10 Re: car won't start
    ^^^X2
  11. #11 Re: car won't start
    Aug 2012
    Oregon
    ^^^X2
  12. #12 Re: car won't start
    Means..he also thinks it's an ignition switch.
  13. #13 Re: car won't start
    I concur with bill
  1. Gtp start up:)
    By bballa0740 in forum Off Topic Discussion
    Last Post: 02-03-2011, 03:29 PM
  2. where to start
    By Jakegday in forum PCM Tuning
    Last Post: 08-04-2009, 12:51 AM
  3. Car tries to start but will not.
    By black2000gtp in forum General Tech Discussion
    Last Post: 08-01-2009, 05:09 AM
  4. The Start
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:43 AM
  5. Start Me Up!!!
    By coolken84 in forum General Tech Discussion
    Last Post: 02-14-2009, 01:47 PM
