Hey all,
Did a coolant flush on my 2000 GT this weekend, got rid of the evil orange/red dexcool and replaced with yellow/green Prestone.
Drained the system by removing the thermostat housing and the lower rad hose. Went pretty well, and have been adding coolant every morning a little bit at a time due to there being (I assume) air in the system. I do seem to be required to add less and less every morning (its been 2 days so far).
However, every morning my temperature spikes to around 100C on the gauge (212F) for about 30 seconds, at which point it drops back to normal which is around 92-95C (198-205F). After this it stabilizes and dos not overheat at all.
My theory is that there is still an air bubble in the thermostat housing, causing a flow issue as the thermostat opens.
Or it could be a defective thermostat (which I did not replace).
Will be bleeding the system again tonight using the bleeder screw on the thermostat housing.
Also may have a LIM gasket leak on the backside on the LIM. (Not leaking into the oil).
I did use 3 coolant sealing tabs as I filled the radiator.
Thoughts?
Thanks
Terry in Winninpeg
