Thread: Did i jut put to much oil in?
Results 1 to 7 of 7
  1. #1 Did i jut put to much oil in?
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    My oil dipstick was reading at the 2nd hole towards the bottom. I added 1qt and now its at the U of FULL that is written onthe dipstick... Is that way to much? Should I go have it drained?
  2. #2 Re: Did i jut put to much oil in?
    Nah, I wouldnt worry about it. I fill mine with 5 quarts and its only a 4.5 system and its prolly 2 dots worth over the FULL mark on the dipstick and I never have issues.
  3. #3 Re: Did i jut put to much oil in?
    Jul 2012
    Chicago
    I normally run an oil filter from an S10 so that the system becomes an even 5 quarts. One time I forgot to buy one for an S10 and over filled a bit. No adverse effects.
    -Carl
  4. #4 Re: Did i jut put to much oil in?
    GTP Level Member
    springfield IL
    An s10 filter will fit...?? Any benefits of it
  5. #5 Re: Did i jut put to much oil in?
  6. #6 Re: Did i jut put to much oil in?
    s10/blazer filter works, but i'd suggest you dont if you've never replaced your motor mounts, the filter can come down and smack the subframe and rip the filter open and you'll have a dead car.
  7. #7 Re: Did i jut put to much oil in?
    Jul 2012
    Chicago
    Whoops my bad. I didn't know this was an issue on the Grand Prixs. There's plenty of room under the Bonneville.
    -Carl
jut, oil
