Thread: Car completely died going down the highway while speeding up...What's wrong?
Results 1 to 14 of 14
  1. #1 Car completely died going down the highway while speeding up...What's wrong?
    Aug 2012
    United States
    I have a 2000 grand prix 3.8 GT with about only 75K on it.
    Well today I was driving down the highway picking up speed. As soon as I got to about 40, the car just shut off on me without any warning at all. It ran perfectly fine before that. No power steering, power brakes. The electrical power all works fine, so I ruled out a battery since it was just recently replaced. I also ruled out the fuel pump & filter since the filter was replaced & I'm getting good pressure when I checked.
    Now the weird thing is that the car will start, but NOT stay on for more than 2 seconds. Unless I keep my foot on the gas pedal while it's on. It was running horribly like put put put... Also white smoke was coming out of the muffler. Right when I let off the gas, it dies completely.
    Also no codes were showing up with my scanner.
    and Also I checked the spark plugs, wires, and coil packs. All looked fine and were just recently replaced.
    What could be my issue? Is there anything I can check without having to buy new parts before I know what the problem is?
    Any help would be greatly appreciated! Thanks :-)
  2. #2 Re: Car completely died going down the highway while speeding up... Can't it out! Hel
    Try unplugging the MAF sensor and see if it runs better.
    And just for the random stall, its possible the crank sensor could be going aswell.
  3. #3 Re: Car completely died going down the highway while speeding up... Can't it out! Hel
    Ohio
    uhhh gt or gtp?
  4. #4 Re: Car completely died going down the highway while speeding up... Can't it out! Hel
    Aug 2012
    United States
    Sorry I forgot to state that it's a GT
  5. #5 Re: Car completely died going down the highway while speeding up... Can't it out! Hel
    what five finger said.......^^^^^^^
  6. #6 Re: Car completely died going down the highway while speeding up... Can't it out! Hel
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    LOL maybe upper intake cracked and it is sucking coolant in
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  7. #7 Re: Car completely died going down the highway while speeding up... Can't it out! Hel
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    ... X2
  8. #8 Re: Car completely died going down the highway while speeding up... Can't it out! Hel
    Ohio
    white smoke....hmmm im gonna say
    1.) Massive vacuum leak
    2.) coolant is getting in the cylinders
    3.) time to do a uim swap and lim gaskets...
    HAVE FUN!!!!
  9. #9 Re: Car completely died going down the highway while speeding up...What's wrong?
    if unplugging the maf doesn't fix it. Check for this issue.
    http://www.grandprixforums.net/97-03...ure-60667.html
  10. #10 Re: Car completely died going down the highway while speeding up...What's wrong?
    Grand Island, Nebraska
    My car does this exact same thing, except after like 30 seconds it will start up and run fine.
  11. #11 Re: Car completely died going down the highway while speeding up...What's wrong?
    Jro.. replace your crank sensor.
  12. #12 Re: Car completely died going down the highway while speeding up...What's wrong?
    Jul 2012
    Grand rapids
    Possible it could be head gaskets check compression
  13. #13 Re: Car completely died going down the highway while speeding up...What's wrong?
    Quote Originally Posted by 02wdave View Post
    Based on what diagnostics? A single stall on a 3800 related to a head gasket?
  14. #14 Re: Car completely died going down the highway while speeding up...What's wrong?
    I did.
  1. How to avoid a speeding ticket
    By WhiteKnight07 in forum Off Topic Discussion
    Last Post: 06-11-2012, 07:06 AM
  2. 22 mile an hour over speeding ticket
    By gpgtman83 in forum The Rant Forum
    Last Post: 02-09-2011, 11:48 PM
  3. so i got a speeding ticket
    By gtpinsc in forum Off Topic Discussion
    Last Post: 04-15-2010, 09:20 PM
  4. How to get out of speeding tickets!
    By KawaFord in forum Off Topic Discussion
    Last Post: 12-07-2009, 10:48 AM
  5. Speeding Ticket
    By VGPGT in forum Off Topic Discussion
    Last Post: 08-13-2009, 12:30 PM
