Thread: Oil leak onto exhaust manifold
Results 1 to 6 of 6
  1. #1 Oil leak onto exhaust manifold
    Jul 2012
    Waterford,MI
    SO.....I changed my valve cover gaskets about 3 weeks ago, maybe longer now. The leak stopped but now I have leaking over the front exhaust manifold. But the oil is missing the spark plugs. Any thoughts?
  2. #2 Re: Oil leak onto exhaust manifold
    GrandPrix Junkie
    St. Louis
    What brand vc gaskets did you install? Did you install new vc bolt grommets as well? If not they are known to leak again.
  3. #3 Re: Oil leak onto exhaust manifold
    Jul 2012
    Waterford,MI
    Quote Originally Posted by FordMan77 View Post
    The gaskets and grommets are both from felpro.
  4. #4 Re: Oil leak onto exhaust manifold
    GrandPrix Junkie
    St. Louis
    Stupid question, but after you replaced everything did you clean all the old stuff off w/ engine degreaser? Could just be leftovers.
  5. #5 Re: Oil leak onto exhaust manifold
    Jul 2012
    Waterford,MI
    yup, cleaned everything with degreaser. everything was fine until about a day or two ago.
  6. #6 Re: Oil leak onto exhaust manifold
    And you cleaned the groove in the valve cover and the surface of the head where it sits right?
  1. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  2. Cracked exhaust manifold
    By PALMCASTER GT1 in forum General Tech Discussion
    Last Post: 02-10-2012, 10:22 PM
  3. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  5. exhaust manifold ?
    By 04GTPCOMPG in forum General Tech Discussion
    Last Post: 11-09-2009, 03:20 PM
