Thread: Will these lifters work??
Results 1 to 16 of 16
  1. #1 Will these lifters work??
    GT Level Member deadsnake's Avatar
    Round lake, IL
    GM CTS-VR Racing Team Hyd. Lifters
    I found a good deal on these...will they work on our cars? I think they are similar to LS7
    '04 MC Intimidator SS,'96 Camaro Z28 ,'98 GTP 12.9 trap
    '93 383 stroked Trans am (Crashed),
    '93 Chevy c1500 Pickup Indy500 Special edition,
    '01 VW GTI Garrett 50 trim, '98 GTX clone (Current car) Working on Top swap!
    Ohio
    They'll work, but how good of a deal did you find?
    Ohio
    Kinda pointless though because these are for engines seeing well over 8k which your gp will never in its dreams see
  4. #4 Re: Will these lifters work??
    Round lake, IL
    True I am building a turbo GT, with a bottom end bored over 30
  5. #5 Re: Will these lifters work??
    Why no stock bottem end?
    Ohio
    Lol man why the **** would you waste the money? The blocks are thin enough. Stock engine with turbo. You mess with the bottom end you are asking for trouble
  7. #7 Re: Will these lifters work??
    Round lake, IL
    The lifters would only set me back 50 bucks, the bottom end was rebuilt and bored over a few years back. The only think I want to do to the bottom is lifters and single roller( If beneficial)
    Ohio
    Bottom end fully assembled?
  9. #9 Re: Will these lifters work??
    Round lake, IL
    Yes it is.
    Ohio
    Go for it then..
  11. #11 Re: Will these lifters work??
    Round lake, IL
    I mean will they affect performance in a bad way? Will they perform pretty much like stock but better at high rpms?
  12. #12 Re: Will these lifters work??
    the lifters arent going to be your holdup with high rpm oiling, its going to be the little baby oil passages in the block.
    i would just use a stock set of lifters, you're never ever going to rev your car past like 7000 anyway.
  13. #13 Re: Will these lifters work??
    Ohio
    What nick just said ^^ if the shop that bored out that block knew anything, it would have been to open up the oil galleys from the tiny ass holes they come with from the factory.
    Those lifters will want too much, and the block wont be able to assist them....therefore, you could be looking at a big problem down the road.
    This is a 3800, not a cts-v race car that spins at 8k+ with just about 1/2" oil galleys.
    I never thought i would have to bring these out again
    but here goes nothing
  14. #14 Re: Will these lifters work??
    Ohio
    this is the oil passage in your oil filter neck....
    Could you see the problem???? lemme help you
    Those weren't even the oil galleys, the oil galleys are the holes that feed the mains and allow the crankcase to be properly oiled..Boring it out without taking these into consideration can result in very bad results in some cases.
    If you want to actually learn about your engine, other than the regular day to day things that people talk about on here, give this thread a look. You may have to register on here to go beyond the first page.
    3800 OILING -TECH- analyzing deficiencies - 3800Pro.com Forum
  15. #15 Re: Will these lifters work??
    Round lake, IL
    Got ya.... so even though the LS7 lifters are a tad more you wouldnt invest in them for a turbo build?
    Ohio
    No we are saying buy regular ls7 lifters. Not racekar lifters
  1. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  2. Remote start - Used to work great now after some messing around it does not work.
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2012, 11:24 AM
  3. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
  4. Lifters
    By 2000 Black 2dr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 01:12 PM
  5. Bad lifters?
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2010, 07:59 AM
