Thread: P0300, P0171 issues. Lots of info logged+pics
Results 1 to 17 of 17
  1. #1 P0300, P0171 issues. Lots of info logged+pics
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Hey guys last week I started having some issues after replacing the spark plugs, wires and sending unit.
    The p0171 code was always there, the p0300 was new.
    The car is cammed, headers, exhaust and hv insert.
    It is missing really bad, at idle its very hard to tell, when you start driving it misses and hesitates really bad, at high rpms it gets somewhat steady but still has a slight miss and it boggs.
    Cylinder test read 150 in cylinders 1-3-5-2. on 4 105 and 125 on 6.
    As stated before brand new plugs (104's coppers gapped at 60) ZZP wires.
    YES all cylinders are getting great spark.
    Pulled the valve cover to look for rocker/rod damage.... nothing abnormal that I can tell. Here are pcis of the head.
    Thank you in advance.
    '04 MC Intimidator SS,'96 Camaro Z28 ,'98 GTP 12.9 trap
    '93 383 stroked Trans am (Crashed),
    '93 Chevy c1500 Pickup Indy500 Special edition,
    '01 VW GTI Garrett 50 trim, '98 GTX clone (Current car) Working on Top swap!
  2. #2 Re: P0300, P0171 issues. Lots of info logged+pics
    I think your gap is way too big for your mods.
    I'd try .050.
  3. #3 Re: P0300, P0171 issues. Lots of info logged+pics
    Scanning for misfires on cylinders...which cylinders are lighting up?
  4. #4 Re: P0300, P0171 issues. Lots of info logged+pics
    Round lake, IL
  5. #5 Re: P0300, P0171 issues. Lots of info logged+pics
    Apr 2009
    Fort Worth TX
    Before he was seeing missfires on 4 and 6.
    P0304 and P0306
    http://www.grandprixforums.net/n-ins...ion-65155.html
  6. #6 Re: P0300, P0171 issues. Lots of info logged+pics
    Round lake, IL
    this is first start up after reconnecting the ICM, coils wires and rocker install. There is a sensor right on the throttlebody at beginning of vid, with the orange connector... it was slightly separate from its hole it was idling okay, i went ahead and screwed it all the way in(its also glued down for some reason) then the car started idling very low around 400 500 RPM took it around the block and as i went to a stop it died on me, happened multiple times....
  7. #7 Re: P0300, P0171 issues. Lots of info logged+pics
    Have you tried unplugging the MAF and starting it?
    Did you also check for vac leaks like I told you to?
    Things I would do...
    1) Spray around for vac leaks with carb cleaner
    2) Delete that stupid EGR, my Pacesetter's hated it on there
    3) Make sure the TPS, IAC, MAF are good...if you know someone with another 3800, swap them and see
    4) What did the ICM test say?
  8. #8 Re: P0300, P0171 issues. Lots of info logged+pics
    Apr 2009
    Fort Worth TX
    It almost sounds like the IAC is fighting a vacuum leak.
    That's not a sensor you tightened. It's the IAC.
  9. #9 Re: P0300, P0171 issues. Lots of info logged+pics
    Round lake, IL
    Could a far gap cause the missfire?
  10. #10 Re: P0300, P0171 issues. Lots of info logged+pics
    .060" is the factory gap size.
    I run .050" because there is less of a chance for misfires, hell...Bio was lazy and ran .035" or something.
  11. #11 Re: P0300, P0171 issues. Lots of info logged+pics
    Round lake, IL
    SO am I more prone to missfire or not likely
  12. #12 Re: P0300, P0171 issues. Lots of info logged+pics
    Apr 2009
    Fort Worth TX
    You have a compression of only 105 psi on cylinder number 4, there is noticeable ticking noise from the engine, a bad miss and we're talking about spark plugs.?.?.?
    Hurt me
  13. #13 Re: P0300, P0171 issues. Lots of info logged+pics
    Round lake, IL
    I have no idea lol... i just want this damn thing to work already. Its weird how it started doing this RIGHT after i swapped plugs and wires
  14. #14 Re: P0300, P0171 issues. Lots of info logged+pics
    -_-
    Closer gap = less chance of a miss. To an extent.
    It's also those bullsh1t ZZP plug wires. They are awful. And you are 110% SURE you have them in the right order?
    Coils go...
    6
    and the motor is...
    2 4 6
    ENGINE
    1 3 5
    I wouldn't be too worried about compression, I'm sure the guy just didn't install those rings correctly when he rebuilt it.
    Figure out the vac leak.
    Figure out the misfire if the vac leak doesn't solve it.
    Then go from there.
    You're worrin' about the wrong crap.
  15. #15 Re: P0300, P0171 issues. Lots of info logged+pics
    Round lake, IL
    Yes its correct, il give vacuum a test, car drives ok when IAC is not fully screwed in, no miss under 2K from 2-4K it misses
  16. #16 Re: P0300, P0171 issues. Lots of info logged+pics
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Did you ever find the problem?
  17. #17 Re: P0300, P0171 issues. Lots of info logged+pics
    Dec 2011
    Decatur
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 3 Weeks Ago, 11:56 PM
  2. YO dudes/gals - Newbe here to read lots of good info.
    By blu fuz in forum Introductions/Noob Questions
    Last Post: 05-24-2012, 09:52 PM
  3. LOTs of helpful modding/3800 info
    By JoRoW99 in forum General Tech Discussion
    Last Post: 08-19-2011, 09:40 AM
  4. Bad idle and RPM issues not to forget codes P0303, P0341, AND P0300
    By jessiinicole in forum Off Topic Discussion
    Last Post: 03-08-2010, 02:27 PM
  5. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
