Thread: HELP smoke coming from engine
Results 1 to 20 of 37
  1. #1 HELP smoke coming from engine
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    Hey my GP just now has steam coming from under the ignition coils, what is it. it just happened now and when i came back to park i saw coolant on the floor. Could the rad hose under the ignition coil not be on all the way? The engine is getting hot too, need to drive in a half an hour so i need the help.
  2. #2 Re: HELP smoke coming from engine
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    that or leaking coolant elbow. have you checked the LIM???
    4 out of 3 people have trouble with fractions
  3. #3 Re: HELP smoke coming from engine
    Jan 2012
    Anaheim, Ca
    Quote Originally Posted by lrscgod View Post
    still pretty new and well what is the LIM?
  4. #4 Re: HELP smoke coming from engine
    Shellman Bluff, GA
    what year is the car?
  5. #5 Re: HELP smoke coming from engine
    Jan 2012
    Anaheim, Ca
    2007 gp base, where is that located? and ya ill check the elbows and is it safe to drive just need to drop my bro off at work.
  6. #6 Re: HELP smoke coming from engine
    Mar 2012
    NC
    I would check the clamp on that radiator hose under the coil. Otherwise you may have the infamous coolant elbow leakage beginning.
  7. #7 Re: HELP smoke coming from engine
    Mar 2012
    NC
    LIM = Lower intake manifold.
  8. #8 Re: HELP smoke coming from engine
    Shellman Bluff, GA
    the lower intake manifold
  9. #9 Re: HELP smoke coming from engine
    Mar 2012
    NC
    Doubtful that it's LIM gaskets then.
  10. #10 Re: HELP smoke coming from engine
    Jan 2012
    Anaheim, Ca
    ok, al we just replace the water pump just last week so it cant be that, but we did take the rad hose out under the ignition coil to drain the coolant and was a BI*** to put back on but wse got it in but could have we not put it in all the way?
  11. #11 Re: HELP smoke coming from engine
    Mar 2012
    NC
    Quote Originally Posted by SF9777 View Post
    That would be my first thing to go to if it was a pain in the balls.
  12. #12 Re: HELP smoke coming from engine
    Shellman Bluff, GA
    right, check the little plastic elbow the comes out from the front of the Lower Intake. the are prone to cracking
  13. #13 Re: HELP smoke coming from engine
    Shellman Bluff, GA
    yes it could.
  14. #14 Re: HELP smoke coming from engine
    Jan 2012
    Anaheim, Ca
    ok i just came back from droping my bro off at work, we had to stop just once on the freeway because of the coolant was hot and said so on the DIC. after that the car needle stayed between the middle and the hot part. I'm waiting for the car to cool down then go across to my autozone and get some more coolant. i could only see one of my coolant elbows since it was hot and its seemed fine and no leak ( how many elbows are in the car again just 2 right?).
    You guys answer this for me, its been hot as hell over here in SoCal, we only filled up the car with one gal of 50 50 coolant and had no money for more, so could have these factored into this? Also when i got back i can here the steam coming out and saw it coming from the same spot and im guessing its coming from that hose and im going to check it ASA the car cools down. if it is the hose should i just push it back in more and its those pinch clamps could the clamp be a little messed up cause it was a a pain in the as to get that thing to stay open or pinched in so we could put it back on. also does it matter hows that clamp is supposed to be positioned? like the the two things that i have to pinch to get it open was facing the floor so should it be like that?
  15. #15 Re: HELP smoke coming from engine
    Mar 2012
    NC
    Let car cool down...replace pinch clamp with screw clamp.
  16. #16 Re: HELP smoke coming from engine
    Jan 2012
    Anaheim, Ca
    Quote Originally Posted by hitman92499 View Post
    Ya i was thinking just that do you knows if those clamps are cheap at autozone? and what inch will i need like say a two?
  17. #17 Re: HELP smoke coming from engine
    Mar 2012
    NC
    Yeah, they're only a couple bucks. If you don't have cash for more coolant, slide the pinch clamp back, open the screw clamp and then put it around the hose. No hose removal necessary.
  18. #18 Re: HELP smoke coming from engine
    Jan 2012
    Anaheim, Ca
    cool thanks, but dont i have to take the hose out if i want to take the pinch clamp off? it does not open like the screw clamp.
  19. #19 Re: HELP smoke coming from engine
    Mar 2012
    NC
    just pinch it and slide it back to the middle of the hose.
  20. #20 Re: HELP smoke coming from engine
    Jan 2012
    Anaheim, Ca
    Ok and just leave it there, and may be cut it off later or what? Ill be heading to my Autozone in a little bit and try this out and ill keep you guys updated.
    Just a side note, Thanks you guys for your quick responses, ever since i joined this sight a few months ago its been a great big help. thanks to all you guys, if i was still on yahoo asking these questions i would have not gotten a reply until like a week later.
  1. Light Smoke coming from engine comp, Infrequent
    By PlayingMechanic in forum General Tech Discussion
    Last Post: 02-11-2012, 12:29 PM
  2. S.O.S smoke coming from exhaust...
    By kyleinkman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 07:33 PM
  3. Smoke Coming out Of my breaks?
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2009, 05:34 AM
  4. smoke coming through the a/c vents
    By bonerjamz03 in forum General Tech Discussion
    Last Post: 08-19-2009, 07:05 PM
  5. Replies: 6
    Last Post: 10-11-2008, 09:30 PM
