Thread: Engine swap advice???
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
  1. #1 Engine swap advice???
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    Alright well I just lost my engine, and there ain't no bringing it back... Spun rod 4...fml... Well I'm gonna be pullin one from the junk yard, and I've never dropped an engine in. I was hoping u guys new of all the things I need to make this happen. Obviously a good engine, and a puller. But what else?? Like gaskets, ect... And does the radiator need to come out??? Thanks in advance. Really appreciate it.
  2. #2 Re: Engine swap advice???
    Mar 2012
    NC
    The swap itself is pretty straight-forward. Remove the oil filter adapter to make things easier. Don't forget about unbolting the torque convertor!
  3. #3 Re: Engine swap advice???
    Mar 2012
    NC
    BTW, you'll need an oil filter housing gasket, and I recommend doing LIM gaskets at the same time. Make sure you get an engine with a warranty, too. It's worth it even if it's only a 30 day.
  4. #4 Re: Engine swap advice???
    May 2012
    pensalvania
    Quote Originally Posted by hitman92499 View Post
    well, since the lim and uim's are new on my engine, i was gonna just swap those to the other motor along with new gaskets anyway. what about the seals between the engine and tranny?
  5. #5 Re: Engine swap advice???
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Your probably thinking of the rear crankshaft seal as hitman said or the input shaft seal on the transmission. I'd just leave them be if they're not leaking....IMO ......If the seal is defective or put in wrong then you gotta pull a buncha s*** out again
  6. #6 Re: Engine swap advice???
    May 2012
    pensalvania
    possibly stupid question, but do any of you know if advance or auto zone rent pullers out??
    engine hoist. cause thats gonna kill my engine budget if i gotta buy one out right lol
  7. #7 Re: Engine swap advice???
    remove the ac compressor and the power steering pump from the block and just let them hang there.
  8. #8 Re: Engine swap advice???
    Mar 2012
    NC
    No gaskets there but you could replace the rear crankshaft seal if you want while you're there.
  9. #9 Re: Engine swap advice???
    May 2012
    pensalvania
    im trying to be as cost efficient as possible. so im going to do the bare minimum for now. this was kinda an unexpected "dent" in my budget... and i always thought there was some kinda sela between the motor and tranny? what seals it then? lol
  10. #10 Re: Engine swap advice???
    None?
    The input shaft goes through the torque converter and into the motor.
    Thats where the power is transfer to the transmission.
  11. #11 Re: Engine swap advice???
    Jan 2012
    Indianapolis
    There are no seals between the engine and tranny. The block of the engine is bare metal against the bellhousing of the transmission. Theres no fluid flow between the engine and trans
  12. #12 Re: Engine swap advice???
    May 2012
    pensalvania
  13. #13 Re: Engine swap advice???
    Jan 2012
    Indianapolis
    You talking about an engine hoist (cherry picker) or a puller like for a harmonic balancer? I'm sure they rent a puller for a harmonic balancer. Not sure tho. Just calll them or maybe someone else on here knows....
  14. #14 Re: Engine swap advice???
    Jan 2012
    Indianapolis
    If you have a garage then you could use this.
    Chain Hoist - Low Sale Prices on this 1 Ton Chain Hoist
    Put a steel bar across at least 5 of the rafters and then attach the hoist to the steel bar. Ive used one of these pulling an engine out of my buddies talon. It works really nice cuz you dont have to work around a big clunky crane
  15. #15 Re: Engine swap advice???
    May 2012
    pensalvania
    Quote Originally Posted by indygrandprix View Post
    damn, wish i had a garage that could support that lol
  16. #16 Re: Engine swap advice???
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    my dad and i did a swap on his 2000 GPGT back when he had it and we found that it was easier jacking the car up real high and lowering the engine to the floor and getting the new engine in the same way much easier than lifting it out and lowering the new one it. just a simple tip haha hope it helps
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  17. #17 Re: Engine swap advice???
    Jan 2012
    Indianapolis
    What mwinters said is probably what your gonna want to do. Its 4 bolts on the subframe and then disconnect everything from the car and undo the struts and tie rods and a few other things and it will drop down.
    Be a little more careful than this tho
    GM 3800 Engine Transmission removal (Pontiac Grand Prix) - YouTube
  18. #18 Re: Engine swap advice???
    See billboost37's thread in the how to section.
  19. #19 Re: Engine swap advice???
    May 2012
    pensalvania
    ive certainly never heard of this method, but it sounds interesting.
  20. #20 Re: Engine swap advice???
    May 2012
    pensalvania
    how high would i have to jack it up to make it clear the motor? and does the tranny have to come with it?
  1. plannin on doin a l67 swap any advice
    By kyleheine298 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2011, 06:20 AM
  2. So im getting ready to do a top swap, any advice?
    By thunder71173 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2011, 04:41 PM
  3. 98 GTP L67 to L32 swap advice
    By jamjam in forum General Tech Discussion
    Last Post: 10-17-2010, 11:49 PM
  4. needs advice: SS m0 kit vs Top Swap
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2010, 10:01 AM
  5. swap advice
    Last Post: 07-30-2009, 09:28 PM
