Thread: '01 GT - No power, won't rev above 4k, hesitates badly.
Results 1 to 11 of 11
  1. #1 '01 GT - No power, won't rev above 4k, hesitates badly.
    Jul 2012
    VA
    Hey guys, really hope you can help me out here!
    I have an '01 GT with 158k on the clock. Today while I was driving to work I suddenly had a huge loss of power, the engine wouldn't rev past 4000rpm, and I couldn't get past about 55mph. The engine was also hesitating very badly. If I put the pedal to the floor the motor makes a horrible knocking or detonation noise tryin to rev it quickly or above 4000rpm. Had a friend stick his hand behind the exhaust while I revved it and he said there wasn't much flow and the exhaust was really hot.
    There strangely is no CEL....
    Things I reckon may be wrong: clogged cat, clogged fuel filter, bad fuel pressure regulator, dieing ffuel pump, or bad MAF.
    Anyone else have these symptoms and what the fix ended up being?
    Thanks in advance for your help!!!!
  2. #2 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Never Never Land
    Clogged cat I bet. My 99 knocked so bad we thought it was something mechanical. Replaced a motor only to find the same knocking. Hollowed out the cat for a temporary fix and she runs great.
  3. #3 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Out West
    Plugged cat.
    Otherwise sounds like normal GT performance.
    Whine with your Cheese?
  4. #4 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Mar 2012
    NC
    I'm thinking clogged cat as well.
  5. #5 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Jul 2012
    VA
    Thanks y'all.
    Just one cat on the POS?
  6. #6 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Never Never Land
    Yup, just one. I've heard of people removing the o2 sensor to test if the cat is clogged. It gives the exhasut an alternate path. I'm not sure how well that works though.
  7. #7 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Mar 2012
    NC
    It works very well. That hole is enough for the exhaust to escape and allow the engine to breathe enough.
  8. #8 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Never Never Land
    There you go. Remove the o2 sensor and report back.
  9. #9 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Jul 2012
    VA
    Thanks for your help. Cat was completely clogged, replaced and car drives almost like new again.
  10. #10 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Nov 2011
    Pike, NY
    10 Gauge.......had the exact same thing happen here on my 00' GT.........mine backed up stream and burned out the air check valve when the heat built up. I replaced the crappy stock unit with an EBay Magnaflow direct fit......$164 shipped to my door. My car acted the same as yours....no power after only a minute of driving it up the road. It'd start fine and run decent for that time, but once the exhaust backed up.....crapola.
    The car now runs like a raped ape and has a nice full tone to it. I had to replace the rear O2 sensor cause the old one was seized into the old cat, but all is good to go now.
  11. #11 Re: '01 GT - No power, won't rev above 4k, hesitates badly.
    Jul 2012
    VA
    I had the shop cut out the old one and just weld in a universal which looked to be bigger and less restrictive than the OE converter. They were able to salvage the o2 sensor. $210 installed and a new fuel filter and she hasn't run this good since 2001. Easily a 2-3x power increase.
  1. Car hesitates under hard acceleration
    By GTLGDP in forum General Tech Discussion
    Last Post: 03-10-2012, 12:16 AM
  2. car want go and hesitates someone help
    By chevyman39452 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-27-2012, 03:06 PM
  3. Hesitates to start
    By kking89 in forum General Tech Discussion
    Last Post: 09-09-2011, 09:34 PM
  4. Car Hesitates When Floored
    By 04GTPeeingOnU in forum General Tech Discussion
    Last Post: 07-14-2009, 07:05 AM
  5. replaced power steering pump and now it is squeeling and leaking badly! Help
    By Cheri in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2009, 08:10 AM
