Thread: 08 base noise at wot
Results 1 to 11 of 11
  1. #1 08 base noise at wot
    SE Level Member grey08's Avatar
    Jun 2012
    cleveland ohio
    i have a base 08 and makes a funny noise on right side of engine any ideas? only happens at wot
  2. #2 Re: 08 base noise at wot
    St. Louis
    Could you describe the noise? Is it a squeal? A grinding sound? Heck, take a vid of it and post it if all else fails.
  3. #3 Re: 08 base noise at wot
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    lol, yea, not the best description haha. knocking? creaking? could be an engine mount maybe. that's the only guess i could make with the details given.
  4. #4 Re: 08 base noise at wot
    GT Level Member GMCustomerService's Avatar
    Michigan
    Quote Originally Posted by grey08 View Post
    I agree with the others…what type of "funny noise"? Whine, grind, growl, etc. Please provide a more detailed description.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  5. #5 Re: 08 base noise at wot
    Jun 2012
    cleveland ohio
    lol sorry! the noise kind of sounds like a growling griding type of noise from right upper side like how a bad wheel bearing sounds
  6. #6 Re: 08 base noise at wot
    St. Louis
    Maybe take the belt off and spin the pulleys by hand and see if one of them sounds noisy or dry. Could be the A/C compressor as well, or possibly the alt. Can you duplicate the noise while it's in Park w/o revving it to hell and back?
  7. #7 Re: 08 base noise at wot
    Jun 2012
    cleveland ohio
    no no noise in park only when driving and wont do it unless im wot.
  8. #8 Re: 08 base noise at wot
    Jun 2012
    cleveland ohio
    do you think it could be related to plugs and wires?
  9. #9 Re: 08 base noise at wot
    Apr 2009
    Fort Worth TX
    Now how the heck would plugs and wires make a grinding noise on your engine?
    Check your pulleys: alternator, idler, water pump, AC, power steering
    Remove the belt and spin them. They should be smooth as silk. If any one makes any noise at all then it'll make some serious noise at 5000 RPM.
  10. #10 Re: 08 base noise at wot
    May 2012
    pensalvania
    yea, when you go wot u put everything under a strain that you wouldn't normally see. so the pulleys are moving alot faster. much like my bad wheel bearing, i imagine the faster they move, the louder they get...
  11. #11 Re: 08 base noise at wot
    Jun 2012
    cleveland ohio
    i will try that when i get a chance thanks
  1. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
  2. Base gtp?!?!?
    By Iceman6669 in forum General Grand Prix Discussion
    Last Post: 03-22-2012, 09:51 PM
  3. Base model vs GT
    By midrange in forum General Grand Prix Discussion
    Last Post: 02-16-2012, 01:35 PM
  4. Supercharger for Base 05 GP
    By kyledc2000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2010, 09:55 PM
  5. ZZP's customer base
    By matt5112 in forum Off Topic Discussion
    Last Post: 11-19-2009, 10:39 PM
