Thread: A/C compressor hose has a hole in it...
Results 1 to 6 of 6
  1. #1 A/C compressor hose has a hole in it...
    Mar 2012
    Michigan
    With everything i got a quote for 300. I got to thinking last night, what if i just take an aluminum can, cut it to fit the hole so it goes around the hose and take 2 hose clamps an clamp the piece of aluminum can to the spot where the whole is??? would it work??
  2. #2 Re: A/C compressor hose has a hole in it...
    wont work, its not an exhaust pipe.
  3. #3 Re: A/C compressor hose has a hole in it...
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    yea. too high of pressure. you could just replace the line yourself for much cheaper. not much to worry about since the hole p[robably drained all the free-on out.
  4. #4 Re: A/C compressor hose has a hole in it...
    Mar 2012
    Michigan
    Are there any special tools required?
  5. #5 Re: A/C compressor hose has a hole in it...
    May 2012
    pensalvania
    just a standard ratchet and wrench set. just make sure your positive that theres no freon in those lines first, cause that s*** can send ya to the hospital if ya get enough on your hands.
  6. #6 Re: A/C compressor hose has a hole in it...
    I'd have it done for $300. Because you should have a new accumulator and orifice tube since moisture got in there. Then vacuum it down and fill with freon to the proper level. $300 isn't a bad price at all.
  1. Hole prep
    By tdm571 in forum Visual/Body Modifications
    Last Post: 04-04-2011, 07:31 PM
  2. hole in VC
    By gtpinsc in forum General Tech Discussion
    Last Post: 01-23-2011, 10:50 AM
  3. Some A** HOLE egged my car
    By hanback in forum The Rant Forum
    Last Post: 11-09-2010, 11:13 AM
  4. Could this be a hole in #1 piston?
    By guys00gtp in forum Off Topic Discussion
    Last Post: 06-24-2010, 03:27 PM
