Thread: Possibly overheating
Results 1 to 11 of 11
  1. #1 Possibly overheating
    Jul 2010
    Detroit
    99 Pontiac Grand Prix GT 3800
    My car has been acting weird lately. Usually the car starts instantly all the time but lately if its been sitting over night or for a few hours it takes a minute to crank. It acts like it doesn't want to start but once it does you can turn it off then back on and it starts instantly.
    When you start driving the car the temp gauge will start to rise like normal but when it gets to about 195 it instantly drops down to 175-180. Then it rises again to about 200 and will stay there for about 15-20 mins of driving. Then when you stop at a light the outside temp on the hvac display will start to rise 20-40 degrees more then what it actually is outside. Then the coolant temp starts to rise to 235-240 and the fans come on. As I drive it will come down to 215-220 until I stop or park again. When I open the hood both radiator hoses are rock hard and really hot. Engine feels hotter then its suppose to be. I already replaced the thermostat(twice), coolant temp sensor and radiator cap.
    Any ideas?
  2. #2 Re: Possibly overheating
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    any white smoke out the tail pipes when you first cold start it?
  3. #3 Re: Possibly overheating
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Sounds like you have air in the system. Have you checked your coolant levels to see if you're consuming any? Check for any signs of wetness on the manifold bolts and by the coolant elbows?
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  4. #4 Re: Possibly overheating
    St. Louis
    Check your fuel pressure regulator. Pull the vac line off and see if gas comes out. If so, replace the FPR.
    On the overheating issue, did you bleed the cooling system properly when you did the t-stats? These engines are very picky on having air trapped in the system and will do what you described when there is. There is a proceedure on here if you search " cooling system bleed" or something like that. It's been talked about a lot.
    Jul 2010
    Detroit
    Quote Originally Posted by bmx6454 View Post
    No
    Quote Originally Posted by 99XC600 View Post
    Yes I've had to add coolant to it. I topped it off yesterday and today it's down a couple of inches from the filler. It is wet right above the water pump and I noticed this black plastic like thing hanging out from between the block and I guess manifold(?). I already had the intake manifold gaskets replaced unless he only did the upper.
    Quote Originally Posted by FordMan77 View Post
    I did it a few times. Where exactly is the fuel pressure regulator?
  6. #6 Re: Possibly overheating
    May 2012
    pensalvania
    ahhh, coolant above the water pump points towards your coolant elbows. your not seeing coolant puddling on the ground??
  7. #7 Re: Possibly overheating
    Apr 2012
    Wilbraham MA
    Quote Originally Posted by NerdPower View Post
    No
    Elbows will need to be replaced. Process is as follows
    1. Disconnect negative battery cable
    2. Drain Coolant
    3. Remove Serpentine Belt
    4. Remove Alternator
    5. Disconnect Heater Hoses
    6. Remove Tensioner assembly
    7. Remove Elbows
    8. Remove broken pieces of elbows from assembly and intake (Yes, they will break)
    9. Insert new elbows and re-assemble (Should take about an hour)
    While you are at it, check for any signs of leakage on the driver side of the engine, look for signs of pooling or staining on top of the transmission. If you do, you will need to replace the lower LIM gaskets as well.
  8. #8 Re: Possibly overheating
    St. Louis
    Facing the motor from the front end, the fuel pressure regulator is on the fuel rail towards the right side. A little round thing about 1" diameter with a single black vacuum line attached to it.
    Jul 2010
    Detroit
    Problem solved....I think?!?!? Will see tomorrow. I changed the water pump and poured antifreeze into the block where the thermostat is. I bleed the system and it seems like it worked. I think air was trapped in the block like someone mentioned and the water pump looked original.
    Jul 2010
    Detroit
    There was no fuel in the vac line so I'm thinking it's time for a tune-up.
  11. #11 Re: Possibly overheating
    St. Louis
    You don't want to see fuel come from that vac line. If it's dry its good. Wet= bad FPR.
    And plugs and wires are a good idea if they're old. Just don't use any platinum plugs. Copper or irridiums only in these motors. Lifetime wires from Autozone and you're set. Gap to .052-.055.
  1. WTB-BBV, MAF, possibly 42# Inj
    By SDGTP99 in forum Wanted To Buy - Parts
    Last Post: 02-21-2012, 02:40 PM
  2. Possibly looking for a new car
    By Bakerdd in forum Off Topic Discussion
    Last Post: 06-19-2011, 07:35 PM
  3. Could I maybe possibly almost???
    By jerZcavy4120 in forum General Tech Discussion
    Last Post: 04-28-2011, 10:22 PM
  4. Possibly of new car
    By jakewet28 in forum Off Topic Discussion
    Last Post: 03-21-2011, 07:01 PM
