Thread: 01 top swap with 97gtp parts
Results 1 to 20 of 27
  1. #1 01 top swap with 97gtp parts
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    I found a gtp looks to have everything still under the hood at the local junk yard. My question is can i use these car to get all my parts. I know the 97 gtps had a few different things than the later years besides the tranny. Please help fast because it may not be there long. O and also how can i tell if the blower is bad and if it is is it a hard fix worth doing.Thanks again!
  2. #2 Re: 01 top swap with 97gtp parts
    Jan 2012
    Philadelphia
    take off the belt see if the S/C has play or not take the heads, belt, crank LIM, S/C, LIM, Bolts and everything if some parts are bad you can always find another im sure if its like any JY around here it wont be there long so you better go soon! id go tomorrow, and im sure you can snag the parts dirt cheap
  3. #3 Re: 01 top swap with 97gtp parts
    Dec 2011
    Decatur
    Plays bad right? i thought it was but just to be sure and the guy said $400 for supercharger and heads is that high? and i want to take a list up there to get a price on everything.
  4. #4 Re: 01 top swap with 97gtp parts
    Jan 2012
    Philadelphia
    play is bad but a little bit of play may be okay, it may just need a new coupler witch is cheap and super simple to replace especilly if your blower is off the car, and yea thats way to high if your not sure if it works, a guy on here has nice heads for $200 shipped and you can find a Gen 3 for near nothing. if he wants that much dont go for it unless its for the whole set up, S/C, LIM, heads, pulleys, tensioners, crank pulley, injectors, fuel rails, bolts, etc..
  5. #5 Re: 01 top swap with 97gtp parts
    Dec 2011
    Decatur
    Ok thanks thats what i figured... thats why i want a list of everything to see if he'll give me a deal or not.
  6. #6 Re: 01 top swap with 97gtp parts
    Donating Users timboku's Avatar
    Montgomery, IL
    I got a complete top swap off a 98 which will work for your 01. can do 300 for everything including all brackets, bolts, heads, fuel rail, injectors, blower, etc. Blower has not play in it and rotors look good. It has about 110k on it but everything looks good. Located a little west of chicago. LMK
  7. #7 Re: 01 top swap with 97gtp parts
    Jan 2012
    Philadelphia
    id say at a junkyard id maybe pay $250-$300 for everything (if i needed it), if it was in a u-pull-it yard you could get it for that much or less, but if its at a small yard he will most likely charge alot for it.
  8. #8 Re: 01 top swap with 97gtp parts
    Dec 2011
    Decatur
    Yea its a you pull it yard and to timboku..if they wont lower there price i will pm you on that
  9. #9 Re: 01 top swap with 97gtp parts
    Montgomery, IL
    all good. good luck. Just let me know. Got to take everything off the motor )
  10. #10 Re: 01 top swap with 97gtp parts
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    400$ is pretty bad... i would pay like 140$ for heads/sc at the yard by me. y not just pull the whole engine? much simpler.
  11. #11 Re: 01 top swap with 97gtp parts
    Texas
    97 M90 has the goofy vacuum tree on it. You could essentially cap it off of need be. Be Leary of the heads. Early production 97's make it difficult to fit some aftermarket valvesprings on. Other than that it should work fine. Personally, I wouldn't purchase it for more than $300. Have the heads been checked for cracks etc? May be worth having them tested at a machine shop for peace of mind.
    85 Corvette
    01 TA
    03 Z06
  12. #12 Re: 01 top swap with 97gtp parts
    Dec 2011
    Decatur
    No the heads havent been checked and i havent had the chance yet to go and inspect it since ive been working. Im hoping to go look monday. Im going to take a list of stuff i need and see if he'll give me a deal or not. Also if i did happen to install this on my car with headers and a full inter cooler could i run a 3.3 pulley?
  13. #13 Re: 01 top swap with 97gtp parts
    May 2012
    pensalvania
    http://www.grandprixforums.net/safel...car-17482.html --good one for that question. i would expect alot of kr with just that for a 3.3
  14. #14 Re: 01 top swap with 97gtp parts
    Dec 2011
    Decatur
    I looked at the link and it said a stage 2 or 3 would allow for a 3.25 pulley or lower on stock car thats why i asked the question because i didnt think that was right. I know i have a higher compression so maybe a 3.4 pulley?
  15. #15 Re: 01 top swap with 97gtp parts
    May 2012
    pensalvania
    With a good octane, 3.4 might be okay
  16. #16 Re: 01 top swap with 97gtp parts
    May 2012
    pensalvania
    And that was right. Stage 2, or especially 3 require a lot of goodies added..
  17. #17 Re: 01 top swap with 97gtp parts
    Dec 2011
    Decatur
    93 octane with or without a booster? i think thats the highest i have around here except race gas.
  18. #18 Re: 01 top swap with 97gtp parts
    Texas
    Quote Originally Posted by 01GrandPrixTURBOGT View Post
    You would be dumb not to.
    85 Corvette
    01 TA
    03 Z06
  19. #19 Re: 01 top swap with 97gtp parts
    Full size, headers, 3.4 pulley on 94 octane.
    That's about it.
  20. #20 Re: 01 top swap with 97gtp parts
    Dec 2011
    Decatur
    dumb not to do what? check the heads?
  1. 284 for sale and swap parts, lots of parts
    By 2000gtpbt in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 04-07-2012, 09:05 AM
  2. Transmission Slipping on 97GTP. Interchange?
    By the496rocket in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2011, 03:46 PM
  3. Bought 97GTP - Plans for mods~
    By Space Dynamics in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 11:03 PM
  4. 97gtp
    By vicaras in forum Introductions/Noob Questions
    Last Post: 04-23-2009, 03:19 PM
