Thread: HELP!!!
Results 1 to 14 of 14
  1. #1 HELP!!!
    Jun 2012
    Golden Eagle, IL
    ok i took the TB off and cleaned it, put it back on and now i have a crappy idle and car shows reduced engine power, help
  2. #2 Re: HELP!!!
    St. Louis
    What year do you have? I suspect a vacuum leak now. Spray some carb or brake cleaner around the TB and see if the motor changes tone. Did you replace the TB gasket before reinstalling?
  3. #3 Re: HELP!!!
    Yeah did you put in a new gasket?
  4. #4 Re: HELP!!!
    Jun 2012
    Golden Eagle, IL
    its an 04 gp gt, and sh*t i forgot the new gasket, i just put a layer of rtv hi-temp on it hopfully it fixes it, i will post tomorrow what it does
  5. #5 Re: HELP!!!
    you dont need a new gasket on 04+ cars, you must have messed somethign else up while cleaning the TB.
  6. #6 Re: HELP!!!
    Jun 2012
    Golden Eagle, IL
    ok thanks 5finger, i do have another question, would it matter if i fliped the butterfly plate piece over, idk if i did or not
  7. #7 Re: HELP!!!
    That shouldnt matter at all, it just goes back to where it should.
    I'd take it back off, and make sure it seals right, and clean the maf sensor with maf cleaner and make sure you have no vacuum leaks.
  8. #8 Re: HELP!!!
    Jun 2012
    Golden Eagle, IL
    i anit got MAF cleaner
  9. #9 Re: HELP!!!
    Ontario
    Might it have something to do with that little spring in the TB? Was that touched possibly? I've heard varied reports about that causing idle issues
  10. #10 Re: HELP!!!
    Electrical parts cleaner works too
  11. #11 Re: HELP!!!
    Jun 2012
    Golden Eagle, IL
    is pb blaster considered an electrical parts cleaner??, if i can't figure it out today yet, it looks like im babying it 4 miles to the local auto shop
  12. #12 Re: HELP!!!
    NO don't use pb blaster buy a can of electrial parts cleaner or maf cleaner at your local auto parts store.
  13. #13 Re: HELP!!!
    pb blaster is oil-ish, the last thing you want on your maf.
  14. #14 Re: HELP!!!
    Jun 2012
    Golden Eagle, IL
    ok thats why i asked, im taking to the shop later today.
