Thread: Oilchange Change
Results 1 to 20 of 21
  1. #1 Oilchange Change
    GT Level Member ShadowSwept's Avatar
    Kentucky
    It's time for an oilchange. Yes, I know how to change my oil. Thing is I usually use Penzoil High Mileage 10w40 with ACDelco filter, but I was considering K&N filters and maybe Royal Purple? A friend of mine swears by them and I'm wondering if it's worth the price.
    Also, someone mentioned using a different size filter for some sort of benefit and I was curious as to what that entails. Any opinions?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Oilchange Change
    Why are you running 10W-40?
    Do you have an oil pressure issue?
    On filters, Delcos are pretty cheap (in quality) filters.
    Fram XG, KN, Mobil 1, Amsoil are all good filters.
    Unsure on royal purple filters.
  3. #3 Re: Oilchange Change
    Florida
    You can use a longer filter, that increases the amount of oil in the system by a small bit. No modifications are needed.
    I usually run whichever filter is on sale. Most of the time its either a K&N or a Mobil 1 filter.
    Full synthetic 10w-30 is the stuff to use. Again, it's usually Mobil 1 ($15 for a 5 quart on sale) but this last oil change I got Castrol Edge full synthetic...supposed to be some super dooper awesome-o oil. 5 quarts and a filter for $21...
    Royal purple is good stuff, but I honestly don't see the need to pay the extra.
  4. #4 Re: Oilchange Change
    Oil is oil?
    But 10w40 is not really needed.
  5. #5 Re: Oilchange Change
    Pennsylvania
    You'd be hard-pressed to find a worse filter than a Delco. Use anything else. I use Fram XG (Now Fram Ultra) because it's the best compromise between price and performance for me, and they sell at Walmart where I buy my Walmart SuperTech synthetic oil - one stop shopping.
  6. #6 Re: Oilchange Change
    I buy the cheapest oil and filter autozone has on sale at the time.
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Fram filters are ****. They use cardboard. Do u trust cardboard in your oil filter?
    Sent from my iPhail
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  8. #8 Re: Oilchange Change
    Quote Originally Posted by dazedandconfused View Post
    Sent from my iPhail
    Would you trust an oil filter that uses pure glue as an end cap?
  9. #9 Re: Oilchange Change
    Kentucky
    Wow, everyone's recommending Fram? When I'm not asking everyone seems to be bashing them
    Anyway, 10w40 is really just habit. It's what my grandfather always used and after doing some research I didn't see a problem following suit. Is there really a big difference? Would I be better off with 10w30?
    Since there's still controversy between ACDelco and Fram I may just go with K&N filter. Everyone seems to agree on those
    2003 Grand Prix GT
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I use Castrol GTX Edge 10w30 with a Napa Gold filter
    Sent from my Galaxy Nexus using Tapatalk 2
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  11. #11 Re: Oilchange Change
    GTP Level Member
    Oct 2011
    Raleigh, NC
    What larger filter can be used in a 97 ? I know two sizes will fit, stock and longer. How do i look up the longer filter ?
    1997 Red GTP 182000 miles stock
  12. #12 Re: Oilchange Change
    Quote Originally Posted by ShadowSwept View Post
    I think myself and slow are about the only people who will recommend a fram on here.
    The ultra provides better filtration, uses an extra thick can and metal end caps. Oh and it costs less than a KN/mobil (the premium champion labs filter).
    Quote Originally Posted by GTP in RTP View Post
    Lookup a filter for a 4300 vortec.
    Fram PH3980
    Apr 2012
    Middletown DE
    Napa Gold 1096 for long. I think 1042 is short.
    1993 Oldmobile 88
  14. #14 Re: Oilchange Change
    Kentucky
    I've used Fram and ACDelco, didn't notice any difference. Of course, both times my old 3100 died it was with a Fram filter, but I'm pretty sure that was coincidence.
    Is there any benefit to using the longer filter?
    2003 Grand Prix GT
  15. #15 Re: Oilchange Change
    Yes, more capacity.
    But it can also be a hazard, if your engine mount fails it will crush the oil filter on the subframe and possibly lose oil.
  16. #16 Re: Oilchange Change
    Kentucky
    Oh, sounds fun.
    2003 Grand Prix GT
  17. #17 Re: Oilchange Change
    Jan 2012
    FT Campbell, KY
    K&N HP1001 oil filter and Valvoline SynPower High-Mileage full synthetic 5/30 or 10/30. It's expensive, but it'll set you right. I'm now about 7-9,000 between oil changes.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  18. #18 Re: Oilchange Change
    Pennsylvania
    Uhuh.
  19. #19 Re: Oilchange Change
    BE AWARE.
    If you plan on using the 4300 Vortec filter, you need to have a non-failing lower engine and transmission mount.
    If they are crushed, torn, shredded and need replaced, then all that is going to happen is crush that filter...get a PF47 if you have bad lower mounts.
    Or, put new lower mounts in and go with the 3980.
  20. #20 Re: Oilchange Change
    Portland Oregon
    I'm an Amsoil nutswinger. I've used a lot of the oils and filters you guys are talking about. The delco ones suck for filtration. Your car will start to burn oil over time with royal purple. Mobil 1 and M1 filters are a good combo but won't last much longer than your standard oil change interval. I use Amsoil XL synthetic in my daily with an EA023 filter. I use Amsoil signature synthetic in my race car with an EA023 filter and it stays cleaner longer. Those filters an oil combos work great for extended intervals.
  1. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  2. Tranny Fluid - To change or not to change.
    By midrange in forum General Tech Discussion
    Last Post: 02-15-2012, 11:44 AM
  3. S/c oil change
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2011, 02:44 PM
  4. How to change your oil!
    Last Post: 11-30-2010, 10:34 PM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
