Thread: 01 top swap with 97gtp parts
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: 01 top swap with 97gtp parts
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    I dont have 94 octane around here unless a booster adds 1 octane rating.
    Im just saying, be conservative with pulley choice.
  3. #23 Re: 01 top swap with 97gtp parts
    Texas
    Quote Originally Posted by 01GrandPrixTURBOGT View Post
    dumb not to do what? check the heads?
    Dumb not to drop to a 3.3 with a fullsize intercooler. Personally I'd go down to a 3.25 or 3.1. 3.0 will be pushing it on stock injectors.
    85 Corvette
    01 TA
    03 Z06
  4. #24 Re: 01 top swap with 97gtp parts
    Quote Originally Posted by txslow6 View Post
    High compression, remember?
    You probably won't be able to touch those pulleys without a cam or heads.
    Furthermore, a 3.4 on high comp is about where you start requiring larger injectors than L67.
  5. #25 Re: 01 top swap with 97gtp parts
    Dec 2011
    Decatur
    So i should be safe with a 3.5 pulley
  6. #26 Re: 01 top swap with 97gtp parts
    Texas
    LOL at high compression. Sorry I always crack up when I hear guys say a L36 has high compression. But I see your point. Should still be able to run at least a 3.3 with a fullsize intercooler. And anyone who is going with a top swap should never stay with their NA injectors. They are just asking for trouble. I assumed this top swap would be done correctly with at least L67 injectors which will be plenty for his setup. When in doubt use an injector formula and you will see what the exact size injectors you need. It's not rocket science and takes out the guessing game. And no one in their right mind mind should even consider a set of heads unless knocking on 10's.
    To the op yes a 3.5 pulley is fine if you are paranoid. Happy modding.
    85 Corvette
    01 TA
    03 Z06
  7. #27 Re: 01 top swap with 97gtp parts
    Re-read my post.
    Never mentioned NA injectors.
  1. 284 for sale and swap parts, lots of parts
    By 2000gtpbt in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 04-07-2012, 09:05 AM
  2. Transmission Slipping on 97GTP. Interchange?
    By the496rocket in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2011, 03:46 PM
  3. Bought 97GTP - Plans for mods~
    By Space Dynamics in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 11:03 PM
  4. 97gtp
    By vicaras in forum Introductions/Noob Questions
    Last Post: 04-23-2009, 03:19 PM
