Thread: ABS & Traction Control Lights
Page 3 of 3 FirstFirst 123
Results 41 to 44 of 44
  1. #41 Re: ABS & Traction Control Lights
    Lawrenceville, GA
    Quote Originally Posted by fever42 View Post
    Had the same problem mine was the EBCM dealer wanted 1200 to fix
    Bought one for moran and installed everthing works great.
    I just bought a EBCM from Moran and am getting ready to install. Is this something you can do with reasonable skill and tools or should I seek out a local shop to help. I am pretty comfortable swapping and working on my car but brakes give me a little cause to pause.
    Jerry
  2. #42 Re: ABS & Traction Control Lights
    Donating Users chico's Avatar
    The wheel bearings(hubs) are a common problem I have replaced pass.front twice and the driver front once now I just ordered 2 rear hubs from ZZP for $197 shipped ,so learn to change your own you will save a ton of cash because you will need to replace them all eventually.
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  3. #43 Re: ABS & Traction Control Lights
    SE Level Member gpcustom's Avatar
    Indiana
    I have add a 99 GP and a 01 monte, now a 04 GP, I have resolved the ABS and TRAC OFF light on the GP by replaceing the EBCM, as for the 01 and up I have found a common ground issue, after replacing the ground ( a good ground location ) the issues stopped, and the lights went off. Not sure this will offer a fix for everyone but it doesn't hurt to look or check with a voltage meter. Having a bad ground will cause issues with a scanner not being able to scan the code and PCM/BCM issues.
    Example - To test the ground: Test the negative battery connections to the ground connection.
    Voltage - Should be 13.8 to 14.2 during idle. Now there may be a small difference in the voltage.
    If there is small difference ( Example - At the battery - 14.1 at the ground connection 13.9) then your normally fine. If the voltage difference is more then 0.8 volts or higher, this will normally cause a error and the PCM will is most cases not function properly.
    Now this may not fix everyone's issue but it could fix different ones and the ABS/TRAC issue.
  4. #44 Re: ABS & Traction Control Lights
    California
    ABS light came on.. Neighbor had a scanner it pulled C0550.... Dealer wants $1200.. I told him hey my motor was cheaper...
  1. ABS / Traction Light
    By bcrosby51 in forum General Tech Discussion
    Last Post: 12-20-2008, 06:10 PM
  2. Automatic CLimate control lights.
    By RichCresci in forum Visual/Body Modifications
    Last Post: 08-15-2008, 09:35 AM
  3. !!?best Way To Launch?!! (traction Control)
    By BLACKEDOUTGTP in forum Track Sessions and Kills
    Last Post: 07-29-2008, 12:20 AM
  4. BF Goodrich Traction or Touring?
    By GreenNirvana101 in forum Tires & Wheels
    Last Post: 04-02-2008, 12:10 AM
