Thread: 99 Gt runability issue
Results 1 to 9 of 9
  1. #1 99 Gt runability issue
    Dec 2008
    Kansas
    I bought this car from my wifes uncle. It needed a upper intake manifold so I fixed it and put new Delco wires and plugs in and changed the oil. Car has 82000 and cleaned up very nice. Ok now for the problem. After driving for 15 minutes plus you will pull up to a stoplight and take off and it is at a big loss for power. Pull up to the next stoplight and it will run fine. Since this I have also put a new cat on. I cannot figure this thing out and it does not have any codes or ses light on. Any ideas would be greatly aprreciated. Thanks
  2. #2 Re: 99 Gt runability issue
    Hoffman/Schaumburg, IL
    Check fuel pressure....
    Try the Maf (drive the car with it unplugged)
    Also Check for vacuum leaks, they can cause various problems
  3. #3 Re: 99 Gt runability issue
    Dec 2008
    Kansas
    I will check it out today. Thanks for the reply.
  4. #4 Re: 99 Gt runability issue
    Dec 2008
    Kansas
    Well after digging farther I have found the problem bu dont know whats causing it. When it loses power timing will drop to 0 sometimes -3 from 20degrees. I can stop and take off and sometimes it runs great with full timing, then the next time the timing will retard and have a big loss of power. Any ideas would be appreciated. I have put new acdelco plugs and wires on, maf, icm,and cat in the process of this. Also was told to disconnect o2 sensor and drive it to see if that changed anything with no success. Thanks
  5. #5 Re: 99 Gt runability issue
    I live here. UR LOSN's Avatar
    Rockford, IL
    are you able to scan for knock?
  6. #6 Re: 99 Gt runability issue
    Dec 2008
    Kansas
    No only ablr to watch timing
  7. #7 Re: 99 Gt runability issue
    Dec 2008
    Kansas
    I was able to watch live data on a solus, And its showing 15* of Kr. But 6 out of 10 times it has 0 to 4 and runs fine. Im stumped any ideas?
  8. #8 Re: 99 Gt runability issue
    Dec 2008
    Kansas
    Drove it again and it ran great for 20 to 30 min. Then started acting up a few times. Anybody have any ideas?
  9. #9 Re: 99 Gt runability issue
    Dec 2008
    Kansas
    Nobody has any ideas?
  1. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  2. I have a big issue please help me
    By Goany in forum General Tech Discussion
    Last Post: 12-02-2008, 02:51 PM
  3. Trac Off Issue
    By catcamvegas in forum General Tech Discussion
    Last Post: 07-25-2008, 10:01 AM
  4. Help with this issue please
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-05-2008, 05:00 PM
  5. PM Issue
    By 04DetroitLS in forum Forum Bugs/Suggestions
    Last Post: 05-16-2008, 07:39 AM
