Thread: sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
Results 1 to 6 of 6
  1. #1 sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    May 2012
    nashville,tn
    hello, as the title says and would like to add that after it dies, it starts right back up. as i said it runs. when it gets low on gas it misses and dies. when it has gas it is really sluggish and the gas petal is heavy when i press it. delearship couldn't find anything wrong with it. yet it messed up after i got it back from there. did the fuel filter friday evening. did tune up with fuel injection cleaning. we're thinking it is something in the engine. my mechanic yesterday morning mentioned something about a crank sensor or an ignition censor and that since it runs he's almost positive it's not the fuel pump. please help
  2. #2 Re: sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car r
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    it could be a weak fuel pump. I would check the fuel pressure before you through money at it.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car r
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    No codes? My other car has a bad crank sensor, and all it does is stall occasionally. Maybe a lot of carbon in the egr? Just a guess tho..
  4. #4 Re: sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car r
    May 2012
    Pennsylvania
    I think your "heavy pedal" problem is coming from the throttle body being all gummed up. Take the t-body off and clean it well with carb and choke cleaner and see if that helps. I know mine was practically sealing the brass plate shut with carbon buildup. Then take a rag and soad it pretty good with the C&C and scrub out what you can reach of the upper intake. It does wonders.
  5. #5 Re: sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car r
    May 2012
    pensalvania
    you could also try some sea-foam, never hurts to try that
  6. #6 Re: sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car r
    May 2012
    Toronto
    I have the same thing with my 2004. Stalls when low on fuel, then start up after a few minutes. Noticed my mpg sucks as well. Mechanic cleaned out throttle body, but still does it. He said gm fuel pumps are know for being bad when low on fuel...thats how they get destroyed.
  1. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  2. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  3. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  4. fuel pump runs continually!
    By cam 67152 in forum General Tech Discussion
    Last Post: 10-24-2009, 03:35 PM
