Thread: reduced engine power light - no response
Results 1 to 20 of 23
  1. #1 reduced engine power light - no response
    SE Level Member 04GT's Avatar
    Sep 2011
    Brown City, MI
    got an 04 gp GTna that I just did upper and lower intake gaskets on, ran great for a weeek and now at startup in the mornings (every once in a while) it says "reduced engine power and will not do ANYTHING.
    any help is appreciated on solving this. no engine codes are being thrown
    04 GP GT, dual borla exhaust, 24x4.5in tips, 18'' rims, audiobahn system, tinted 5%, windshield 35%, tinted tails, AVS HL covers
    MSD super conductor plug wires, autolite 606 plugs, shift kit,10k HID Low's, 8k HID High's, 8k HID Fog's
  2. #2 Re: reduced engine power light - no response
    Yoga city
    motor is blown. no for realz imma trolling today at work. good luck with that man
  3. #3 Re: reduced engine power light - no response
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Quote Originally Posted by 04GT View Post
    Put factory wires and plugs on the car... or heh try resetting the computer by removing negative battery cable over night.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  4. #4 Re: reduced engine power light - no response
    Dec 2010
    ATL,Georgia
    Check the throttle body.. this happened to me and my TB wasnt working properly.. switched it out and havent had a problem since
  5. #5 Re: reduced engine power light - no response
    Sep 2011
    Brown City, MI
    Quote Originally Posted by Alix0r View Post
    I don't believe its bad because after I shut it off and back on its fine. but I've been wrong before.
  6. #6 Re: reduced engine power light - no response
    Apr 2012
    Middletown DE
    could be really dirty.. and the plate is getting stuck when its trying to adjust idle or something stupid like that. Get it scanned even if it has no SES light could be a stored code.
    1993 Oldmobile 88
  7. #7 Re: reduced engine power light - no response
    Sep 2011
    Brown City, MI
    Quote Originally Posted by acidcrashdburnd View Post
    could be
    when I did
    when I did the intake I cleaned the TB and everything sspotless.
  8. #8 Re: reduced engine power light - no response
    my 03 pick up had the same problem, it wound up being a bad maf.
  9. #9 Re: reduced engine power light - no response
    Apr 2012
    Middletown DE
    What he said. Check the connection then try cleaning the maf. But still get codes pulled.
    1993 Oldmobile 88
  10. #10 Re: reduced engine power light - no response
    Sep 2011
    Brown City, MI
    ok maf sensor reads ok on the scan tool. tps reads 1% at. idle... and no ENGINE codes but I did. find a transfer code which might have something to do with it because when It freaks out. it says "service traction control system" too. the code is:
    C0240 powertrain control module traction control not allowed
  11. #11 Re: reduced engine power light - no response
    Mar 2012
    NC
    Do the 04's have an adaptation that needs to be done after throttle body services like the Subaru/Saabaru?
  12. #12 Re: reduced engine power light - no response
    Sep 2011
    Brown City, MI
    god I hope so..
  13. #13 Re: reduced engine power light - no response
    Dec 2010
    ATL,Georgia
    See thats why i am leaning towards the TB.. mine works perfectly fine right up until thw point when i did a gasket change and clean the TB... after i put it back on it started to mess up..
    Can you scan? What is the throttle volts reading?
  14. #14 Re: reduced engine power light - no response
    Sep 2011
    Brown City, MI
    everything is normal on the scan tool... last few days it hasn't done it.. cross my fingers.
  15. #15 Re: reduced engine power light - no response
    did the check engine light ever come on? or just the message in the info center?
    and when it acts up it just idles and the gas pedal dont work?
  16. #16 Re: reduced engine power light - no response
    Sep 2011
    Brown City, MI
    did it this morning but I was ready witth the scan tool got it to throw a code. came up with throttle actuator something ...
  17. #17 Re: reduced engine power light - no response
    Sep 2011
    Brown City, MI
    and yup, when the message appears it runs, barely and the pedal doesn't do anything. turn it off and start it back up and its fine
  18. #18 Re: reduced engine power light - no response
    tps? throttle position sensor?
  19. #19 Re: reduced engine power light - no response
    Apr 2012
    Middletown DE
    Sounds like your ETB control is going bad, or you have a bad connection. Try reseating the plug. If that doesn't work the throttle actuator control is bad/going bad. junk yard part less than $100.
    1993 Oldmobile 88
  20. #20 Re: reduced engine power light - no response
    Sep 2011
    Brown City, MI
    yes, the code is p1518a throttle actuator serial data - where is the ETB control??
  1. Car saying reduced engine power.
    By Louie3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 06:10 PM
  2. Reduced engine power light.
    By joeltonya in forum General Tech Discussion
    Last Post: 03-04-2012, 09:05 AM
  3. Reduced Engine Power/Service Traction Control
    By SteveNMe in forum General Tech Discussion
    Last Post: 08-07-2010, 10:36 AM
  4. Reduced Engine Power???
    By 05gtPEACE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2010, 06:21 PM
  5. Reduced Engine Power
    By donpedro_81 in forum General Tech Discussion
    Last Post: 09-22-2008, 07:20 AM
