Thread: l36 hv3
Results 1 to 20 of 34
  1. #1 l36 hv3
    Jul 2008
    sumter,south carolina
    To ppl that have it... is it worth the 200 bucks. Noticeable gains ?
    02 GTP with mods 05 GP for DD
  2. #2 Re: l36 hv3
    May 2008
    Winnipeg, MB
    it helps in the upper RPM's, such as when you go WOT, try to get it for less then $200 though, its good to know that even a used one is just as good as a brand new one as there is no wear and tear on these things so if you top swap latter it can be sold for what you paid for it hopefully
    2007 Pontiac Grand Prix
  3. #3 Re: l36 hv3
    Jul 2008
    Thanks man... prob never be top swapped. I'll buy a comp g before I do that.
  4. #4 Re: l36 hv3
    Dec 2008
    Lawndale, CA
    You can find them used for $150. It is a nice addition.
  5. #5 Re: l36 hv3
    Omaha, NE
    You'll lose power on the bottm end if you don't tune for it. I only have (or had before the flooding) an 1/8th mile track near me, and my times went up when I installed mine.
  6. #6 Re: l36 hv3
    :facepalm:
    You don't LOSE bottom end power...it is just like header installs on people claiming they lose all this power.
    You don't.
    It shifts the powerband upwards. So the 3800 is making power where the stock intake runners didn't.
  7. #7 Re: l36 hv3
    Jul 2008
    I'm prob gonna toss on my headers off gtp ... hv3 and tune... not tryin to go fast. Just up my highway gas mileage .
  8. #8 Re: l36 hv3
    Omaha, NE
    Gas mileage is for Prius
  9. #9 Re: l36 hv3
    Bluekar gets 30~ish
    Spademadbro
  10. #10 Re: l36 hv3
    Omaha, NE
    Racecars don't need gas mileage.
  11. #11 Re: l36 hv3
    Jul 2008
    K. Well I'm not driving an import. It's my DD. I drive 600+/- miles a week for work. Got a cone slapped on maf housing and already seeing gains there. Figure headers and hv3 with tune should pick it up a Lil more.
  12. #12 Re: l36 hv3
    Omaha, NE
    Your foot will get heavier and you'll lose mileage anyway, ask me how I know! lol
  13. #13 Re: l36 hv3
    Jul 2008
    I ought to be as fast as a stock gtp with a clogged cat with those mods.
  14. #14 Re: l36 hv3
    Dec 2008
    Lawndale, CA
    If you decide to add just a little more power then I recommend the ER rockers. Mine's a daily driver so it makes it a little more fun to drive on the street and on the highway.
  15. #15 Re: l36 hv3
    Omaha, NE
    It would be a close race.
  16. #16 Re: l36 hv3
    Chicago, IL, USA
    Righty...The longer runners increase bottom-end torque, at low RPM's, where the fuel economy is...An HV3 will allow more air to enter the engine at higher RPM's and thus, the PCM will command more fuel to keep the AIR-FUEL ratio in check. So NO HV3 for good fuel economy and older HV3's warp & shrink. I was getting 34-37 highway with my L36 MC (3.05 final). The ONLY mods were: PEM, DP & ZZP under-drive water pump pulley with over-drive alternator pulley, to keep stock belt length. The DP was a Random-Tech (R/T) model for an Impala and uses NO flex-pipe. A used S.S. PLOG will work slightly better (2HP) than a PEM, I've dyno'd at ZZP just with that change. Headers will loose torque below 2,500 RPM, where you need the torque to climb over-passes while on cruise as to avoid the transmission down-shifting, raising engine RPM's and lowering fuel economy.
  17. #17 Re: l36 hv3
    Kansas
    Also.... when your at cruising speeds, keep your foot off the gas like you used to. When I first put my HV3 and headers on, I would be driving along minding my own business. I would then look down and see I was doing well over the speed limit.
  18. #18 Re: l36 hv3
    May 2012
    kent ,washington
    What is this hv3 u talk of
  19. #19 Re: l36 hv3
    Dec 2011
    Philadelphia, PA
    get ER rockers and headers before the HV3, then tune it up
    EDIT: cause i have the hv3 without the rockers and the headers and i feel 0 difference except the car is little louder and breathes better
    AEM bruteforce intake
    Diablo 93 Octane tune
  20. #20 Re: l36 hv3
    Florida
    Im selling one soon if anybody interested.
hv3, l36
