Thread: fuel line bent :(
Results 1 to 14 of 14
  1. #1 fuel line bent :(
    Nov 2011
    Ohio
    So I was changing my fuel filter and twisted the fuel line and it bent open! so whats the replacement way to go really pissed off right now!
  2. #2 Re: fuel line bent :(
    GTP Level Member Rico's Avatar
    Apr 2009
    Fort Worth TX
    Is it a flared fitting with the nut stuck to the tubing?
    You might be able to repair it with a short piece of tubing. Get a flaring tool and reuse the nut. Cut the old flare off and attach your newly flared piece to the original with a compression fitting.
    It's a CUMMINS Dodge not a Dodge Cummins
  3. #3 Re: fuel line bent :(
    Nov 2011
    Ohio
    Yeah its the nut stuck to the tubing but the hole is right next to the nut.
  4. #4 Re: fuel line bent :(
    they sell flared tubing at the parts stores, sometimes a nut with it, you need to find out what size you need and then you can use a compression fitting to seal the old with the new pipe.
    i'd cut the old bent pipe off, with a tubing cutter or real slow with a hacksaw so you dont bend the tubing. take that with you to match it up at the store.
  5. #5 Re: fuel line bent :(
    Apr 2009
    Fort Worth TX
    Hack saw the tube
    Remove nut from filter
    Remove flare from nut (reuse nut)
    Buy a piece of tubing and flare the end
    Put nut on newly flared tubing
    Attach nut and newly flared fitting to filter
    Connect new tube to old tube with a compression fitting
  6. #6 Re: fuel line bent :(
    Nov 2011
    Ohio
  7. #7 Re: fuel line bent :(
    Nov 2011
    Ohio
    Ill do that tomorrow so the best way to cut it off is just slow and steady ?
  8. #8 Re: fuel line bent :(
    Apr 2009
    Fort Worth TX
    Sorry Scotty, you beat me to it. LOL
  9. #9 Re: fuel line bent :(
    Nov 2011
    Ohio
    trying to find out. The thread is same as the filter sure i could bring that in and try and match it. Never thought a fuel filter change could go this wrong really makes me mad!
  10. #10 Re: fuel line bent :(
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by GotThatPower View Post
    You could do like Scotty says and take the nut in and match it up with a nut/tubing combo. They're available at your local auto part store. Pick up a compression fitting while your there.
  11. #11 Re: fuel line bent :(
    Apr 2009
    Fort Worth TX
    Simple fix man.
  12. #12 Re: fuel line bent :(
    yes but a tubing cutter is much better and easier. the type you would use for copper plumbing pipe. the small ones dont cost much, maybe 5 - 6 bucks.
  13. #13 Re: fuel line bent :(
    Apr 2009
    Fort Worth TX
    Hack saw will work...I see you're worried about "lighting up the neighborhood".
    Have you ever used a tubing cutter? This may be your best bet.
    If I were you I would just keep twisting the flange nut until it breaks the tubing off. This way you'll have better control when cutting the mangled end off.
    Keep a fire extinguisher within arms reach if using the hack saw.
  14. #14 Re: fuel line bent :(
    i just like the tubing cutter because it cuts it clean, and kinda flares the end in, so the compression fittings slide right on nice and easy.
  1. Mandrel Bent Pipes vs. Regular Bent - New Exhaust
    By roundbox52 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 10:46 AM
  2. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  3. will a 97-03 L67 SC fuel line fit on my 97 GT L36?
    By mandingo in forum General Tech Discussion
    Last Post: 08-07-2010, 02:53 AM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
