Thread: Car takes longer to start
Results 1 to 8 of 8
  1. #1 Car takes longer to start
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    So I just replace the positive battery terminal bolt so I can add another cable for my amp when I gets here and after I installed it the car took longer to fire up. It took a good 4-5 seconds of cranking before it fired. Now the battery terminals on the battery and on the cable are VERY corroded (I didn't have any rubbing alcohol to clean them up) could this be the problem? Before it didn't take as long with the factory bolt. I drove it for about 7 min to the gas station bought a pop and the car started up a little easier. Did this just happen because I had the battery disconnected because I have done this before but this time I took off the Positive cable and not just the negative. I'm thinking that the corrosion after replacing the bolt just made it harder to fire up. Hope someone can help me otherwise the 350$ worth of audio equipment for my car might have to go back. Hope I am in the right section.
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: Car takes longer to start
    Clean up the termianls.
    And while your under the hood, pull the vac line off the FPR and see if you smell/see fuel come out, thats could be a cause to your long cranks.
  3. #3 Re: Car takes longer to start
    yes that is why. mine usually tuns over on like 1/2 a crank, but after un hooking the battery every time,( if more than 20 to 30 minutes) it will crank like 3 times around before it starts. but only do it one or two times, then go back to normal.
    you just reset the pcm and its relearning.
  4. #4 Re: Car takes longer to start
    GT Level Member ShadowSwept's Avatar
    Kentucky
    And if I do? What's the remedy?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  5. #5 Re: Car takes longer to start
    Replace the FPR.
  6. #6 Re: Car takes longer to start
    Apr 2012
    Dayton, OH
    With just like baking soda and water right? The previous owner must have had a battery blow up on him their is corrosion everywhere around the battery.
    2012 F150 STX
  7. #7 Re: Car takes longer to start
    When you were installing this super new stuff, how many times did you turn the key on and off without starting the engine to test things out?
    Each time you turn the key on w/o starting it..the fuel pump and injectors always prime the cylinders with a little fuel. Do that 3+ times and there's a bit of excess fuel in there. Yes, it'll take longer to start.
    It's totally normal and you caused it. You also fixed the problem the moment you got the car running.
  8. #8 Re: Car takes longer to start
    Apr 2012
    Dayton, OH
    Everything is working fine now. I'm sure it was the PCM just re-learning
    2012 F150 STX
  1. this takes some skill
    By Pkorn in forum Off Topic Discussion
    Last Post: 07-19-2011, 11:01 AM
  2. AC only takes 7oz of freon?
    By SuperSport in forum General Tech Discussion
    Last Post: 07-07-2009, 06:39 PM
  3. Car takes two or three tries to start.. once warmed up starts fine.. Any info?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 03:42 PM
  4. What takes longer? Heads/Cam or Engine Swap?
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 06:38 AM
