Thread: CAI question
Results 1 to 6 of 6
  1. #1 CAI question
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    Hey everyone, so I am making a CAI for my grand prix as after looking around the forum that is what everyone says to do but I have one quick question. Do you just plug up the vacuum line that went in the stock tubing or am I supposed to make a hole for it in the pvc pipe and seal it? Also if I am plugging it up what should I use to do that? Thank you all in advance!
  2. #2 Re: CAI question
    im gunna assume you are 04+.
    just make a hole for it in the tubing somewhere.
  3. #3 Re: CAI question
    Oct 2011
    huntley
    Yes I am, and do I need to seal it up just to make sure there are no vacuum leaks or is that not necessary?
  4. #4 Re: CAI question
    May 2008
    Winnipeg, MB
    yes make sure its a tight fit or else unfiltered air would enter the engine
    2007 Pontiac Grand Prix
  5. #5 Re: CAI question
    Oct 2011
    huntley
    Alright I will do, thank you guys for the help and quick responses!
  6. #6 Re: CAI question
    Pennsylvania
    Quote Originally Posted by hockeybawler View Post
    04+ I just put a hole in the rubber coupler with a small enough drill bit that it's really really tight to get in. And when I take the intake apart I just remove it from the plenum but leave it stuck in the coupler so as not to have it loosen over time.
    Sport Edition Kv5 18x8
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
