Thread: electrical power loss some were
Results 1 to 6 of 6
  1. #1 electrical power loss some were
    SE Level Member erice's Avatar
    Oct 2011
    tampa
    I changed my upper intake a week ago and I thought put everything back where I thought it should go but after a two days of driving the car stalls and with a jump I take it home. I took out the battery and alternator to get them checked and both are fine. All connection are clean. But there is one electrical connector/plug i couldn't find a home for and it's right around the alternator. Its part of the cluster of wires that goes on top of the engine and connect to each fuel injector and whatever else. i'm not sure if thats the issue but theres a power drain some where
  2. #2 Re: electrical power loss some were
    Oct 2011
    tampa
    here a pic
  3. #3 Re: electrical power loss some were
    On the bottom of the alt where we can see it.. there's a flat spot where that connector belongs. You have a couple of lights on when it's running, right?
  4. #4 Re: electrical power loss some were
    Oct 2011
    tampa
    thank you
  5. #5 Re: electrical power loss some were
    Oct 2011
    tampa
    so was that the ground for the alternator?
  6. #6 Re: electrical power loss some were
    That was the control, light and sense wire for the alternator.
  1. power loss
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 01:16 AM
  2. another loss of power :S
    By ChdMcD in forum General Tech Discussion
    Last Post: 07-31-2010, 07:08 PM
  3. power loss
    Last Post: 04-15-2010, 02:57 PM
  4. power loss when hot
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 03:23 PM
  5. Electrical Power Loss
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 06-17-2008, 07:40 PM
