Thread: OMG Idle at 3000 on my 01GT.
Results 1 to 10 of 10
  1. #1 OMG Idle at 3000 on my 01GT.
    Sep 2011
    canyon texas
    Car suddenly will not idle below 3000 rpm. 01 Grand Prix GT 3800 184k New cat at 180k. Runs great. Idle starts at around 2800 and climbs to 3400 and maybe more. I tried the carb cleaner to search for leaks and I don't think it made any diff. in the speed of the engine. Cleaned the MAF sensor. Replaced it 2 yrs ago. Clean pvc and broke the clip that holds it down. gees. Wired up a holder for it. Unhooked and cleaned the pressure switch on top of the pvc. Seems the red rubber is slightly frayed. not the gaskets but the end of the sensor. Where to now my friends.
  2. #2 Re: OMG Idle at 3000 on my 01GT.
    If the PCV valve isn't sealed then that's a huge vacuum leak.
    Fix that.
    Also, could be a bad IAC or TPS.
    Clean those in the TB as well.
  3. #3 Re: OMG Idle at 3000 on my 01GT.
    is the check engine light on? if its on have the car scanned at autozone or who ever you have near by.
    seems like the tps (throttle position sensor) or real dirty throttle body. or a real bad vac leak.
  4. #4 Re: OMG Idle at 3000 on my 01GT.
    Sep 2011
    canyon texas
    Forgot to mention I stopped by AZone this a.m. Code was 0420. a)cat conv. b)02 sensor c)Lg. vac leak d)engine oil leak into exhaust vlv.(doubt it). Like I said the cat was replaced not long ago. Soooo I'm thinkin vac leak and I heard if you spray carb cleaner at a leak the engine will rev. No luck. and thanks
  5. #5 Re: OMG Idle at 3000 on my 01GT.
    Apr 2009
    Fort Worth TX
    That's one hell of a vacuum leak you got there man. Could be IAC...unplug it with the car off and see what happens.
  6. #6 Re: OMG Idle at 3000 on my 01GT.
    Sep 2011
    canyon texas
    OK people... move along. I am up and idling at a mellow 1100 rpm. Cleaned the equipment around the throt. body. I also reset the thingy by turning the ignition to on for 5 seconds and then back to off for 10 sec. and then start. Perfecto amundo or what ever. Thanks so much. When your at whits end it is so nice to have someone to talk to about your baby. Good job.
  7. #7 Re: OMG Idle at 3000 on my 01GT.
    1100 cold? or warmed up. should be about 800 warm.
  8. #8 Re: OMG Idle at 3000 on my 01GT.
    Sep 2011
    canyon texas
    I guess when I looked at the tach I had just turn on the a/c. Its at 8 or 900 now. Nice observation.
    Quote Originally Posted by randywalsh View Post
  9. #9 Re: OMG Idle at 3000 on my 01GT.
    Another fixed Wbody.
    We win.
  10. #10 Re: OMG Idle at 3000 on my 01GT.
    Apr 2009
    Fort Worth TX
    We win.
    Smarty pants! LOL
  1. SVT LIghtning Vs 01GT
    By 01gpgt01 in forum Track Sessions and Kills
    Last Post: 01-08-2012, 06:17 PM
  2. 01gt Vs 2006ish CobaltSS Supercharged
    Last Post: 11-14-2011, 06:31 PM
  3. 01gt vs 04+gt
    Last Post: 09-19-2011, 04:30 PM
  4. Mr. 3000
    By UR LOSN in forum Off Topic Discussion
    Last Post: 10-26-2008, 11:49 PM
