Thread: my grand prix has been stalling out
Results 1 to 5 of 5
  1. #1 my grand prix has been stalling out
    Apr 2012
    downriver
    my grand prix has been stalling out quickly after it has started, the RPM's also jump up and down a lot. the only thing i have done was replaced the manifold air pressure sensor and it did not change anything. i unplug the mass airflow sensor and the problem seems to go away, what could cause this to happen and how can i fix it without spending tons of money.
  2. #2 Re: my grand prix has been stalling out
    Try cleaning the maf. If that doesn't work, likely you need a new one.
  3. #3 Re: my grand prix has been stalling out
    Apr 2012
    downriver
    i found a MAF sensor at the junk yard and put it on, but it did not fix it, is there anything else to check before buying a new one?
  4. #4 Re: my grand prix has been stalling out
    and that maf you bought from the JY should have a warranty on it, 30 days is the norm. if you didn't pick it from a pick and pull.
  5. #5 Re: my grand prix has been stalling out
    is your check engine light on?
    for the maf, you can also check the wires to the plug for the maf, they crack and insulation breaks off and get dry wire.
  1. 95 Grand Prix GTP Stalling Issue??
    By james125 in forum General Tech Discussion
    Last Post: 02-21-2012, 06:36 PM
  2. Stalling Grand Prix?
    By WPT289 in forum Introductions/Noob Questions
    Last Post: 05-24-2011, 05:59 PM
  3. '98 grand prix gtp almost stalling
    By shawnooohhh in forum General Tech Discussion
    Last Post: 03-24-2011, 08:47 AM
  4. 99' Grand Prix 3.8L stalling out when it gets warm
    By Michelleb76 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 04:28 PM
  5. 02 grand prix is stalling
    By some dude in forum General Tech Discussion
    Last Post: 01-28-2010, 03:59 PM
