Thread: clicking sound??? Help
Results 1 to 20 of 20
  1. #1 clicking sound??? Help
    GTP Level Member
    Sep 2011
    Motown
    I have an 06 grand prix, so nothing special, but anyways I now have a ticking sound between 1000-2000 rpm in 4th gear and only 4th gear. I never had this ticking sound before I did a little cleaning. When I say cleaning I mean taking dogbones off and wiping with a rag, putting a cai in, and blew out some dirt in little cracks with air, and changing wire covers. But before I put the cai on I did not hear the ticking sound but after I put it on I can hear it. I dont know if this is false knock or actual knock. Sorry if this is confusing but I am completely lost in solving this problem. thanks for any help.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  2. #2 Re: clicking sound??? Help
    Apr 2009
    Fort Worth TX
    Knock is a vibration fingerprint that is detected by the knock sensors. The PCM will reduce the timing advance until the knock goes away.
    You probably won't hear this.
    You sure it's not your exhaust manifolds leaking?
  3. #3 Re: clicking sound??? Help
    GTP Level Member
    Sep 2011
    Motown
    No its not the exhaust manifold leaking. I only can hear it in 4th gear. I put it in 1st, no problem, put it in 2nd, no problem, put it in third, no problem, put it in 4th, tick tick tick tick, then it reaches higher rpm and gone, no problem. Does the cai have any thing to do with it? its not loud enough for a microphone to pick it up so i cant record it.
  4. #4 Re: clicking sound??? Help
    Apr 2009
    Fort Worth TX
    Chock your tires and put safety break on.
    Turn car on.
    Put in Drive.
    Open hood and see if you can hear a ticking sound.
    CAI has nothing to do with this unless you really messed something up.
    Any DTC's?
  5. #5 Re: clicking sound??? Help
    GTP Level Member
    Sep 2011
    Motown
    Quote Originally Posted by Rico View Post
    Turn car on.
    Put in Drive.
    Any DTC's?
    There is no ticking at idle. If a code was fired wouldnt it turn on the service engine light? Im getting it scanned mon. There is no ticking when i am moving and put it in nuetral then rev. Its not rod knock right? Could it be a wheel bearing? Or am I just the unlucky one and its in the tranny. Theres only 85000 on the car. thx for your help.
  6. #6 Re: clicking sound??? Help
    Apr 2009
    Fort Worth TX
    It could be wheel bearing, axle/CV or crappy L36 differential. Does the noise change when turning the wheel while moving?
    It could be something as simple as an accessory pulley or harmonic balancer. Of course the HB is a real PIA to replace.
    Make sure you tightened the dogbone bolts and make sure that one of the brackets isn't cracked. The one on the drivers side is quite infamous.
  7. #7 Re: clicking sound??? Help
    GTP Level Member
    Sep 2011
    Motown
    alrighty i did about an hour worth of testing to try and figure out what was the tick. I drove uphills, downhills, and drove in neutral. there is a correction I have to make, I can hear the ticking in every gear now 1-4. So what I did i first did the park test you told me to do and everything was normal. I then drove it around. I was going about 55 when i put it in neutral. I reved it slowly has fast, nothing. I coasted, nothing in the wheels. I put it back in drive. Drove down a hill, nothing. Drove it up a hill, tick tick tick tick tick... I noticed whenever I drive it ticks under a "load", like going up a hill. So I think I narrowed it down to the tranny or something to do with it. How can I tell if its the differential or an axle when its just sitting there? Srry if this is confusing but you are a great help. thx alot!!!!
  8. #8 Re: clicking sound??? Help
    Apr 2009
    Fort Worth TX
    How mechanical are you? Do you have the tools and ability to remove a half axle?
    To check a wheel bearing and half axle you have to:
    Chock rear wheels
    Get the vehicle's front wheel up off the ground = jackstands
    Remove the front wheel
    Loosen the spindle/axle nut (36mm or 33mm socket and breaker bar or impact)
    Remove the caliper bracket and brake rotor (I think they're 18mm bolts)
    Loosen the sway bar bushings (13mm) this will let the suspension sag
    Remove the strut bolts (21mm deep-well) and a BFH
    I like to remove the entire strut - makes it much easier to get the axle out
    Rotate the spindle downward and pull the axle up and out of the spindle
    Use a pry bar to remove the axle yoke from the transmission
    At this point you can spin the wheel bearing. It should be as smooth as silk...even the slightest noise while spinning it's toast.
    With the half axle out you can check for CV and yoke wear.
    Or you can just take it to your local garage and let them do it.
    Don't get hurt - safety first
    Check the "How To" section for pictures and more instructions.
  9. #9 Re: clicking sound??? Help
    Put the stock box back in. Hear it? If no, it's some standard noise from not having the noise baffling box. If yes..then look for other items.
  10. #10 Re: clicking sound??? Help
    Apr 2009
    Fort Worth TX
    I gues it's worth a shot.
    Bill what the heck are you doing up? I just got off work.
  11. #11 Re: clicking sound??? Help
    Rico...I'm always here.. when Daves up ... we can be found in the c hatbox talking about nada
  12. #12 Re: clicking sound??? Help
    Apr 2009
    Fort Worth TX
    You guys kill me. A lot of people are glad that you guys are always here though...including me.
    Gooday mate!
  13. #13 Re: clicking sound??? Help
    GTP Level Member
    Sep 2011
    Motown
    By chance if it is an exhaust leak how would i test for it?
  14. #14 Re: clicking sound??? Help
    Apr 2009
    Fort Worth TX
    Tighten the manifold bolts down and see if it changes. It could be the crossover or the downpipe as well. Those are tough to diagnose. Use your ears and while the engine is cold, start it up and feel around all of the joints for escaping exhaust.
  15. #15 Re: clicking sound??? Help
    GTP Level Member
    Sep 2011
    Motown
    Well heres a video i made of the engine bay. It sounds like its coming from the rear of the motor. Either a lifter/rocker or the exhaust manifold. http://youtu.be/dnYxJrAPiFE
  16. #16 Re: clicking sound??? Help
    GTP Level Member
    Sep 2011
    Motown
    Well I put the stock box back in and ...... nothing, no ticking when driving, but when I put the 9" cone back in and I drive ....... tick,tick,tick. So I guess its nothing big. Im thinking it might be an exhaust leak now because the cone pulls in air than stock and the exhaust manifolds can only handle stock. True? And with the cone the exhaust cant get rid of all the air so it finds a small leak in the manifold. True?
  17. #17 Re: clicking sound??? Help
    Apr 2009
    Fort Worth TX
    Bill suggested this earlier in the thread and he thinks it may be the lack of sound baffles that were in the original OEM filter box.
    I'll be a SOB! See, it pays to have the experience level that this guy has.
    Theoretically, the cone should increase the volumetric efficiency of the engine ever so slightly but not enough to exploit an exhaust leak and make the noise that you're hearing. I would try feeling around the exhaust system with your hands while the engine is cold just to make sure. You have about a minute or so before risking a burn.
  18. #18 Re: clicking sound??? Help
    GTP Level Member
    Sep 2011
    Motown
    Ok, thx alot. Should i still get it scanned even though there is no engine light or no?
  19. #19 Re: clicking sound??? Help
    Apr 2009
    Fort Worth TX
    If it's running good I wouldn't worry about it. Enjoy your new filter.
  20. #20 Re: clicking sound??? Help
    GTP Level Member
    Sep 2011
    Motown
    alrighty, sounds good. I just want thank you guys for all your help. I would have been lost without you. thx
  1. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  2. Clicking Sound
    By csssaint12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2010, 09:58 PM
  3. Clicking sound
    By walk76z in forum General Tech Discussion
    Last Post: 07-09-2010, 06:08 PM
  4. clicking sound under dash
    By CTKGP09 in forum General Tech Discussion
    Last Post: 07-15-2009, 01:04 PM
  5. clicking sound under dash
    Last Post: 06-23-2009, 08:05 PM
