Thread: ANother coolant leak
Results 1 to 7 of 7
  1. #1 ANother coolant leak
    PA
    Greetings All,
    I had the upper coolant elbows replaced last summer. I am now getting the 'low coolant' light come on again! Any suggestion as to where the second leak could be coming from? Are there another set of plastic elbows that could be bad? No puddles under the car.
    Thanks in advance for any help! 2002 3.8 V8 no turbo.
    Scott
  2. #2 Re: ANother coolant leak
    your engine could be eating the coolant, via bad intake and upper intake gaskets going bad.
    miles on car?
  3. #3 Re: ANother coolant leak
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    What does the oil look like? Any moisture under the oil fill cap?
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  4. #4 Re: ANother coolant leak
    Cambridge, Ontario Canada
    lim gasket - check oil cap
    2005 E55 - stock
  5. #5 Re: ANother coolant leak
    Is it even low or is the light just on? Could be a bad sensor.
  6. #6 Re: ANother coolant leak
    PA
    Thanks everyone,
    The car has 95K, no water under the cap, water is low. I guess I could change out the sensor, just looking for ideas.
    Thanks much!
    Scott
  7. #7 Re: ANother coolant leak
    St. Louis
    If your coolant is low and there are no external leaks then you probably have leaking LIM gaskets, or a failing UIM. Need to get this taken care of ASAP before you spin a bearing and toast the motor. Search for LIM gasket replacement on here. It's been covered 11 billionity times.
  1. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  2. Need help..coolant leak
    By Ktrap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 11:20 AM
  3. coolant leak
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2011, 11:56 PM
  4. Coolant leak help!!!
    By Sl33p3rGt in forum General Tech Discussion
    Last Post: 12-21-2010, 03:58 PM
  5. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
