Thread: Pully
Results 1 to 7 of 7
  1. #1 Pully
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    what is the deffernce between a Press on pully and a modular?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: Pully
    Banned
    Wichita Falls, Texas
    Modular-
    Press On-
    A press on pulley is going to have to be 'pressed on' and off every time you want to swap a pulley size. The modular set-up is much easier to change pulley sizes becuase all you have to do is take off a few screws each time you want to swap a size.
  3. #3 Re: Pully
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    Modular, also referred to as a MPS(Modular Pulley System) allows you to change pulleys simply by unscrewing anywhere from 1 to 6 screws or nut to change pulleys. Most systems incorporate a "hub" that requires a specialty tool to remove the stock pulley to install the hub. Once that is complete you can change pulleys in a matter of minutes with a couple of typical toolbox tools. Magnuson also made a snout that had a keyed shaft that allowed quick change pulley times.
    A press on pulley is simply that... You need a specialty tool to remove and install each pulley.
  4. #4 Re: Pully
    Aug 2008
    Fayetteville, NC
    ah,so a modular pully would be recommended?
  5. #5 Re: Pully
    Banned
    Quote Originally Posted by offroadfury6 View Post
    Yes.
  6. #6 Re: Pully
    Bastard Reptile's Avatar
    Kansas City, MO
    ^^ X2 on the MPS. You will absolutely not regret it.
  7. #7 Re: Pully
    Aug 2008
    Fayetteville, NC
    good stuff reptile...getting my stuff together, making a list for zzp mods to support this..and waiting on overkill to see about the pcm
  1. pully size? (not the sc pulley)
    By SlowPurpleGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2008, 08:39 PM
  2. Pully
    By 40thgtp in forum General Tech Discussion
    Last Post: 03-24-2008, 07:42 PM
