Thread: car occassionally dies on startup
Results 1 to 15 of 15
  1. #1 car occassionally dies on startup
    Mar 2012
    Prescott, WI
    Hey guys, I have a 2004 GT 3.8 and occassionally on startup, it will die. I mean, it turns over, starts, and dies within 2 seconds. If I start it and give it a little gas, is doesn't die. This only happens when starting, no other time and no other issues. Anyone have a suggestion as to what this may bee? Fuel filter, etc. Thanks
    2004 Grand Prix GT (215,000 miles)
    2003 Ford Ranger FX4 Level II (135,000 miles)
    2002 Harley - Fully modded
    Ohio
    Mileage? Any cel's?
  3. #3 Re: car occassionally dies on startup
    Mar 2012
    Prescott, WI
    215,000 miles. No codes, lights, nothing.
  4. #4 Re: car occassionally dies on startup
    St. Louis
    Remove the throttle body and clean the daylights out of it. Then also use approved MAF cleaner and clean the MAF. The 04+ cars are known to gum up the TB and cause issues. Could be a sticky IAC as well.
  5. #5 Re: car occassionally dies on startup
    that ^^^
  6. #6 Re: car occassionally dies on startup
    Mar 2012
    Prescott, WI
    Will do that this weekend, thanks guys. I am assuming I can just use some carb cleaner to clean the TB?
    Ohio
    Yeah that's fine. It's all the same stuff. But make sure you use maf cleaner only
  8. #8 Re: car occassionally dies on startup
    St. Louis
    And get a new TB gasket while you're at it (if the 04's need it).
  9. #9 Re: car occassionally dies on startup
    Kansas
    04's usually don't need a TB gasket. Just give it a good cleaning and you should be fine. But just check to make sure its not flattened or rotted.
  10. #10 Re: car occassionally dies on startup
    Mar 2012
    Prescott, WI
    Will do thanks!
  11. #11 Re: car occassionally dies on startup
    Portland Oregon
    If in the chance that the previous advice doesn't cure this, I know the 04's have fuel pressure issues occasionally that cause a slow initial rise in fuel pressure. Cycle the key a few times before you start it and see if that helps your issue. If it does you have a few options. Get a fuel pressure regulator off of another 04 and it has to be an 04 at the junkyard. It's located on the underside of the fuel pump lid in the tank. Or a whole new fuel pump assembly.
  12. #12 Re: car occassionally dies on startup
    Mar 2012
    Prescott, WI
    Well, good news, got some mass air flow cleaner and throttle body cleaner, cleaned the hell out of them. THe throttle body literally had probably a 1/4 inch of carbon on it. Cleaned up looks like new and cured my problem! Thanks guys.
  13. #13 Re: car occassionally dies on startup
    St. Louis
    Good to hear. Now you can enjoy your ride again.
  14. #14 Re: car occassionally dies on startup
    Mar 2012
    Prescott, WI
    Yeah, funny thing was the guy at the parts store telling me that I was wasting my money on cleaners and that it won't do anything, and that the real problem is I need plugs and wires. He told me he bet I would be back the next day for them when my cleaners don't work............felt like going back and shoving it in his face cause he was dead wrong
  15. #15 Re: car occassionally dies on startup
    Kansas
    Lol. I would have.
    04+ have known issues that they build up in the throttle body. I'm sure pretty much all 04+ owners have had this issue. Glad it solved the issue, and was a easy fix.
  1. car quitting on startup
    By eightballe in forum General Tech Discussion
    Last Post: 04-07-2011, 10:55 AM
  2. Startup issue with the GTP
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-29-2010, 09:53 PM
  3. Bad lag on startup & accelleration
    By Jsedor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2009, 03:07 PM
  4. knock at startup
    By Jakegday in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 08:01 AM
  5. oil burn at startup?
    By Golgo13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2008, 07:18 PM
